What's the difference between joint velocity and object velocity
Matthew Qi
Post by Matthew Qi »
When I record joint angular velocity v in Graph in V-REP, it only shows a set of one-dimensional data. But when I want to record joint angular velocity in remoteAPI in Python, I use simxGetObjectVelocity but return a set of three-dimensional data, vx,vy,vz
So do these angular velocities has a relationship that v*v = vx*vx+vy*vy+vz*vz?
Thanks,
Mat
Re: What's the difference between joint velocity and object velocity
Hello Mat,
you can get two types of velocities of a joint: the actual joint velocity (i.e. one-dimensional angular velocity, or intrinsic velocity), or the velocity of the joint seen as an object (i.e. the 3-dimensional angular velocity of the object in space).
Inside of the remote API, you'll have to get the joint angular position, and time-derivate it yourself for the actual joint angular velocity.
