How to send image message via b0?
yuntao
Post by yuntao »
I am developing an environment using vision sensor.
But I cannot send the image information got by sim.getVisionSensorImage out via b0.
My vision sensor's resolution X/Y is 640/480.
Is it too large to transport?
It will succeed when the parameter is 32/32.
What method can I use to do with this problem?
Waiting for your reply!
Best wishes,
Yuntao
Re: How to send image message via b0?
can you try the blueZeroDemo1.ttt scene? Does it work? (i.e. it will read an image, send it to B0, while a subscriber will read the image from B0 and apply it to the lower floating view (passiveVision_sensor).
And what happens if you adjust the resolution to 640x480? (make sure to set the same resolution to Vision_sensor and PassiveVision_sensor)
