How do I extract data from excel to vrep
ZZhang
Post by ZZhang » 16 Jul 2019, 16:44
Here is the problem. In my scenario, to achieve a dynamic movement of robot, the position data is saved in an excel file. Is this possible to extract exact data from cell to cell in a table?
I tried to extract the position data from txt file, however, it is difficult to split string of the line to extract each coordinate data. Is there any solution for this problem.
Re: How do I extract data from excel to vrep
Post by coppelia » 18 Jul 2019, 14:50
the simplest is probably to export your data as csv-file (comma-separated-values), which Excel allows to do.
Then you can handle that file as a regular text file. To read a text file from Lua, have a look here for instance.
