Inverse Kinematics Question
engn
Post by engn »
I have a question/problem with inverse kinematics in VREP. I'm using Jaco
Arm as provided by VREP and successfully set up the IK Group between
end-effector and target dummy. I selected all of constraints x, y, z,
alpha-beta, gamma. it gives correct IK result and follows the target in
most cases. However, in some cases, it fails.
1-Using Pseudo Inverse
In the beginning, I tried the pseudo-inverse method. It resulted in strange
behavior (looks like give random angles to joints) if the target is out of
workspace, so it is clear we can understand that. However in some target
poses within the workspace, it gives wrong results, which means IK solver
gives a result and arm is stable but the end effector is not at the target
position and orientation. So there is a large error.
2-Using DLS
As you suggested DLS is more stable but even in some target poses within
the workspace, DLS also gives wrong results, which means couldn't solve.
I'm wondering why it fails to solve even some target poses looks so easy?
Is that caused by lack of IK solver algorithms or something else? I suppose
that the target poses are not required singular configurations because IK
solver gives a result with an error. It does not just move like crazy as
target pose in out of workspace case.
My second question is it possible to determine the singular configurations
from VREP?
Thanks!
Re: Inverse Kinematics Question
my guess is that you have joint limits that hinder the IK solver to reach the position. Or (if your robot is dynamically enabled), it could be that some collisions are in the way (e.g. also self-collisions). IK results can also appear wrong if the start configuration is too distant (in terms of configuration space) from the target. If this is the case, try smaller steps.
You can compute the manipulability value of the current configuration. See sim.getIkGroupMatrix.
engn
Post by engn »
Thank you for your answer. It is caused by joint angle limits and too distant configurations as you said.
I read and implemented simGetIkGroupMatrix. I have some issues about this function. First, I call sim.computeJacobian and then I call simGetIkGroupMatrix, in this way I get current Jacobian. As it is said in document, I calculate sqrt(det(J*JT)) and I can obtain a numeric value. However If I retrieve the manipulability value from API, it is not equal to calculated one so I confused.
Also in some cases, even if the manipulability value from API gives not 'nan' value, it cannot solve the inverse kinematics.
engn
Post by engn »
I also tried it with PhantomXPincher. I can get Jacobian but when I compute sqrt(det(J*JT)), it is not equal to the manipulability value from API.
here is my scene, https://drive.google.com/open?id=195GfC ... YMltlO20GD
Did you check that your Jacobian is the same as the one returned by the API?
Also, there is never a guarantee that IK can be solved. As you know, the Jacobian is the linearization around the current robot configuration. If the target dummy is too far away (or generates too large joint velocities), then IK will overshoot and can become instable.
engn
Post by engn »
Hello again,
I'm not computing Jacobian by myself. I'm getting Jacobian from API, and calculate the manipulability by using this formula sqrt(det(J*JT)). I compare this calculated result with the manipulability value from API.
I used the current value of Jacobian (from API) and, yes, I tried to print Jacobian in the VREP console, this is equal to what I get in python.
So that means, you use the same Jacobian but your calculation of sqrt(det(J*JT)) is different?
Then one other part of the calculation above must be wrong.
You can have a look how V-REP computes this in file v_rep/sourceCode/inverseKinematics/ik/ikGroup.cpp, function CikGroup::getLastManipulabilityValue
