UR5 with RG2 gripper grasping status check
alix
Post by alix »
I am trying to imitate the "UR5withRG2Grasping.ttt".
But there is no method in that scene to check whether the object has been grasped or not. If grasping fails, it still moves to the target position. Is there any way that it can check whether it has grasped the object or not, and only move to target position if grasp was successful ????
thanksss
Re: UR5 with RG2 gripper grasping status check
you can check various things that allow you to detect whether the object was grasped or not. For instance:
  • you can check the gripper angle
  • you can use a proximity sensor to check whether a part is in the gripper
  • you could use an appropriately placed force/torque sensor. This is a bit more complicated than the two other solutions
  • you could use a vision sensor to check whether a part is in the gripper.
  • etc.
alix
Post by alix »
coppelia wrote: 19 Sep 2019, 08:44 Hello,
  • etc.
Thanks a lottt
