Get size of imported model with API
RL_Niryo
Post by RL_Niryo »
Hi Everyone,
I do not know if I catch a bug or I am just badly using one API's function
I'm progressing in my sorting chain project, and now, I aim to generate multiple type of cans from models that I created.
These cans do not have the same size and I do not want to hard code each of them.
So, to get cans' size, I thought about using sim.getObjectSizeValues, nevertheless I do not get result I expected.
The code used is:
h=sim.createPureShape(partType,19+4,{0.08,0.08,0.085},1,nil)
--h = sim.loadModel("models/mine/can_texture.ttm")
sim.setObjectParent(h,model,true)
--can_shape={0.08,0.08,0.085}
can_shape = sim.getObjectSizeValues(h)
a = sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_x)
b = sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_x)
print(can_shape)
print(a,b,(b-a))
I firstly tried to import my model (which is a customized Cylinder of size 8x8x8.5 cm) then I tested to create a Cylinder with PureShape, but I both cases sim.getObjectSizeValues gave me {1,1,1} and the variables a & b (which should give boudingboxes min/max on x axis) give also 1.
Do you have an idea why I'm not getting expected results ?
Re: Get size of imported model with API
sim.getObjectSizeValues returns 3 variables that are correctly scales during scaling operations. If those variables are not correctly initialized with the size of the object, then you won't be able to use them.
Retrieving the bounding box of the object is the better way of doing, as you mention it. You should however use the API functions in following way:
function getObjectBoundingBoxSize(h)
    local r,xmin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_x)
    local r,xmax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_x)
    local r,ymin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_y)
    local r,ymax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_y)
    local r,zmin=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_min_z)
    local r,zmax=sim.getObjectFloatParameter(h,sim.objfloatparam_objbbox_max_z)
    return xmax-xmin,ymax-ymin,zmax-zmin
RL_Niryo
Post by RL_Niryo »
Hi coppella,
Thx a lot ! I have been tricked by Lua :p
Nevertheless, it is now working.
Cheers from Niryo and have a good day ;)
