After I get the 3D coordinates of the object in the vision sensor frame, I want to extract their corresponding 2D coordinates in the output image.
I try to use some codes like
cam_intrinsics = np.hstack((self.cam_intrinsics, np.zeros((self.cam_intrinsics.shape[0], 1), dtype=self.cam_intrinsics.dtype)))
p = np.matmul(cam_intrinsics, camera_vertices)
p[0] = p[0] / (p[2])
p[1] = p[1] / (p[2])
However, there remains an offset from the ground truth to my calculations, I'm not sure what is wrong with my thoughts.
I also found something similar to my question, however, I did not understand the answer completely.
viewtopic.php?t=5435
coppelia wrote: ↑11 May 2016, 16:27If you need to x/y position of the target object in the vision sensor's reference frame, then simply do:
The reference frame of a vision sensor has Y pointing up, x pointing left, and z pointing in the viewing direction.Code: Select all
transformMatrix = simGetObjectMatrix(shapeObj, frontSen) xRel=transformMatrix[4] yRel=transformMatrix[8] zRel=transformMatrix[12]
