How to build a cable with robot
ringo
Post by ringo »
Dear all,
I am trying to create cables with robot like a sample video on Youtube :https://www.youtube.com/watch?v=VS8Vctoxguo and I am making them from this sample rope : http://www.coppeliarobotics.com/scenesA ... peTest.ttt
I have already read this thread : viewtopic.php?t=2665
But still now I don't understand how to make cables.
Could you show me an example or let me know how to create cables?
This is what I made up to now : https://drive.google.com/file/d/1NiteSP ... sp=sharing
Re: How to build a cable with robot
you have two ways of creating a cable as in the video: you can do this kinematically, or dynamically.
With the dynamic approach, it is similar to a rope. But instead of using spherical joints, use revolute joints that operate in spring-damper mode, otherwise your cable won't have any rigidity. So something like:
base --> revJoint1a --> auxMass --> revJoint1b --> link --> revJoint2a --> auxMass --> revJoint2b --> .. revJointRot
Consecutive joints should be perpendicular to each other. The last joint should be along the cable direction, and free, to allow a rotation along the cable. Then use a loop closure construction.
ringo
Post by ringo »
Dear coppelia
Thank you very much.
I'm trying to make the cables.
https://drive.google.com/file/d/1ZMg2bb ... sp=sharing
I made 3 types of cable.
One is that as you wrote here, which I named IK-Hybrid, this doesn't work well.
another is
dummy --> revJointA1 --> Sphere1 --> revJointB1 --> Cylinder1 --> revJointA2 ... --> Cylinder --> SphericalJoint --> EndPoint(Small static object) --> Dummy
, I named IK because I added IK function on top of the cable
the other is like
dummy --> revJointA1 --> revJointB1 --> Cylinder --> revJointA2 --> revJointB2 ... --> Cylinder --> SphericalJoint --> EndPoint(Small static object)
, which I named J_J_C and I used IK function too.
I have other questions.
1. Do you mean that auxMass is like small sphere, link means cylinder?
2. All objects except base should be respondable and dynamic?
3. All joints should be "inverses-kinematics" mode with Hybrid operation in order to operate in spring-damper mode like this picture?
ringo
Post by ringo »
Dear coppelia,
Actually my colleague found a sample file which I saw on Youtube. I use them.
I'm not sure that I can upload this file here for others who don't have and don't have any idea.
If you let me do that, I will renew this post.
Anyway really thank you for your advices. These help me a lot!!
RobAtLab
Post by RobAtLab »
You could upload to a dropbox, google drive or other such cloud storage platform, then put a link to it here.
ringo
Post by ringo »
OK! Thank you.
Same robot and cable on Youtube, https://drive.google.com/file/d/1xO7M6L ... sp=sharing
I added Custom UI and you can change joint and lengths as you want, https://drive.google.com/file/d/1HiFUvo ... sp=sharing
    h=sim.getObjectAssociatedWithScript(sim.handle_self)
    hTip = sim.getObjectHandle("cable_tip")
    hTarget = sim.getObjectHandle("cable_target")
    child = sim.getObjectsInTree(h,sim.object_joint_type,0)
    xml = readXML()
    ui=simUI.create(xml)
    simUI.setPosition(ui,1077,85,true)
    num = table.getn(child)*0.5
    for i= 1,num,1 do
        InitsetSliderValue(1000+i)
        InitsetSliderValue(2000+i)
    makeIK()
function InitsetSliderValue(id)
    hJoint = HandleFromID(id)
    val = sim.getJointPosition(hJoint)
    simUI.setSliderValue(ui,id,val*180/math.pi,true)
sliderChange_callback=function(ui,id,value)
    sim.setJointPosition(hJoint,value*math.pi/180)
    --set Tip and Target
    child = sim.getObjectsInTree(sim_handle_scene,sim.handle_all,0)
    for i=1,table.getn(child) do
        -- hLastBody_bef = hLastBody
        if string.match(sim.getObjectName(child[i]), "cable_body") == "cable_body" then
            hLastBody = child[i]
        if string.match(sim.getObjectName(child[i]), "cable_orientTarget") == "cable_orientTarget" then
            hLastTarget = child[i]
        if string.match(sim.getObjectName(child[i]), "cable_orientTip") == "cable_orientTip" then
            hLastTip = child[i]
    -- print(sim.getObjectName(hLastBody))
    pBody = sim.getObjectPosition(hLastBody,-1)
    oBody = sim.getObjectOrientation(hLastBody,-1)
    sim.setObjectPosition(hTip,-1,pBody)
    sim.setObjectOrientation(hTip,-1,oBody)
    sim.setObjectPosition(hTarget,-1,pBody)
    sim.setObjectOrientation(hTarget,-1,oBody)
function renewUI()
    x,y=simUI.getPosition(ui)
    simUI.destroy(ui)
    xml = readXML()
    for i= 1,num,1 do
    simUI.setPosition(ui,x,y,true)
function readXML()
    xml = [[
        <ui closeable="true" on-close="closeEventHandler" resizable="true">
            <tabs>
                <tab title="CABLE" layout="grid">
                    <button text="Add cable" on-click="addCable" />
                    <button text="Delete cable" on-click="delCable" />
                    <button text="Renew UI" on-click="renewUI" />
                    <br />
                    '<label text="Joint Name" />'
                    '<label text="Joint A" />'
                    '<label text="Joint B" />'
                    <br />
        for i= 1,num,1 do
            if i == 1 then
                xml = xml .. '<label text="Joint Ori" />'
                xml = xml .. '<label text="Joint '..-2 + i..'" />'
            xml = xml .. '<hslider minimum="-180" maximum="180" on-change="sliderChange_callback" id="'..1000+i..'"/>'
            xml = xml .. '<hslider minimum="-180" maximum="180" on-change="sliderChange_callback" id="'..2000+i..'"/>'
            xml = xml .. '<br />'
        xml = xml .. '</tab></tabs></ui>'
    return xml
function HandleFromID(id)
    if id == 1001 then
        hJoint = sim.getObjectHandle("cable_jointA")
    elseif id == 2001 then
        hJoint = sim.getObjectHandle("cable_jointB")
    elseif id > 2000 then
        num = id - 2002
        hJoint = sim.getObjectHandle("cable_jointB" .. num)
    elseif id > 1000 then
        num = id - 1002
        hJoint = sim.getObjectHandle("cable_jointA" .. num)
    return hJoint
function closeEventHandler(h)
    sim.addStatusbarMessage('Window '..h..' is closing...')
    simUI.hide(h)
function makeIK()
    if sim.getIkGroupHandle("cable_straight@silentError") ~= -1 then
        hIKgroup = sim.getIkGroupHandle("cable_straight")
        sim.removeIkGroup(hIKgroup)
    if sim.getIkGroupHandle("IK_Group@silentError") ~= -1 then
        hIKgroup = sim.getIkGroupHandle("IK_Group")
    hIKgroup = sim.createIkGroup(0,{sim.ik_damped_least_squares_method,3})
    hBody = sim.getObjectHandle("cable_body")
    hOrientTip = sim.getObjectHandle("cable_orientTip")
    sim.createIkElement(hIKgroup,0,{hOrientTip,hBody,-1,sim.ik_alpha_beta_constraint})
    for i=0,num-2 do
        hBody = sim.getObjectHandle("cable_body"..i)
        hOrientTip = sim.getObjectHandle("cable_orientTip"..i)
function addCable(ui, id)
        if string.match(sim.getObjectName(child[i]), "cable_jointA") == "cable_jointA" then
            hLastJointA = child[i]
        if string.match(sim.getObjectName(child[i]), "cable_jointB") == "cable_jointB" then
            hLastJointB = child[i]
            hLastTip = child[i]
    hNew = sim.copyPasteObjects({hLastTarget,hLastJointA,hLastJointB,hLastBody,hLastTip},0)
    sim.setObjectPosition(hNew[2],hNew[4],{0,0,0.01})
    sim.setObjectParent(hNew[1],hLastBody,true)
    sim.setObjectParent(hNew[2],hLastBody,true)
    pLastTip = sim.getObjectPosition(hLastTip,-1)
    oLastTip = sim.getObjectOrientation(hLastTip,-1)
    sim.setObjectPosition(hNew[1],-1,pLastTip)
    sim.setObjectOrientation(hNew[1],-1,oLastTip)
    -- sim.createIkElement(hIKgroup,0,{hLastTip,hLastBody,-1,sim.ik_alpha_beta_constraint})
    sim.setObjectParent(hTip,hNew[4],true)
    pNewTip = sim.getObjectPosition(hNew[5],-1)
    oNewTip = sim.getObjectOrientation(hNew[5],-1)
    sim.setObjectPosition(hTip,-1,pNewTip)
    sim.setObjectOrientation(hTip,-1,oNewTip)
    sim.setObjectPosition(hTarget,-1,pNewTip)
    sim.setObjectOrientation(hTarget,-1,oNewTip)
    makeIK()
function delCable(ui,id)
            hLastTip = child[i]
    pOldTarget = sim.getObjectPosition(hLastTarget,-1)
    oOldTarget = sim.getObjectOrientation(hLastTarget,-1)
    sim.removeObject(hLastBody)
    sim.removeObject(hLastJointA)
    sim.removeObject(hLastJointB)
    sim.removeObject(hLastTarget)
    sim.removeObject(hLastTip)
    sim.setObjectPosition(hTip,-1,pOldTarget)
    sim.setObjectOrientation(hTip,-1,oOldTarget)
    sim.setObjectPosition(hTarget,-1,pOldTarget)
    sim.setObjectOrientation(hTarget,-1,oOldTarget)
    makeIK()
function sysCall_nonSimulation()
    -- local selectedObjects=sim.getObjectSelection()
    -- if selectedObjects and (#selectedObjects==1) and (selectedObjects[1]==h) then
    --     if simUI.isVisible(ui) == false then
    --         simUI.show(ui)
    --     end
    -- else
    --     simUI.destroy(ui)
    --     print(ui)
    -- end
function sysCall_cleanup()
    simUI.destroy(ui)
    print("CLEAN UP")
