how can I auto start a add-on script through cmd
cong.guo
Post by cong.guo »
I try
./coppeliasim.sh -b simAddOnScript-addOnScriptDemo.lua -s 5000 -q
I suppose it could auto start the sim and auto start the add-on
but the result shows that I still have to press the add-on -> addOnScriptDemo button
I try any way that shows in Command line like -a xxx or -b xxx but non of them works.
I hopes I could get some suggest from you.
Thank you :)
Re: how can I auto start a add-on script through cmd
You have to name the script simAddOnScript_xxxx.lua (note the underscore instead of the dash)
cong.guo
Post by cong.guo »
Thank you for your help. I rename the script and it run automaticlly when sim start.
But it's really not a very good design that I have to control this by file name & file place -_-!
I read the doc many times and still can't get this.
Well, it's in the manual:
http://www.coppeliarobotics.com/helpFiles/en/addOns.htm
Additionally, you can run add-on scripts from arbitrary locations via a command line switch:
http://www.coppeliarobotics.com/helpFil ... ndLine.htm
I don't know why you didn't manage to do it that way. Maybe it's a bug
