How to select multiple objects?
Elin
Post by Elin »
I wonder know how to select multiple objects considering I have nearly a hundred objects to delete. Someone said shift+click and drag, I can't understand how to operate it. Can you give some suggestion?
Thank you very much.
alix
Re: How to select multiple objects?
Post by alix »
Elin wrote:
09 Jan 2020, 09:48
Hi Elin,
Just go to 'Scene Hierarchy' pane on left , select fist object you want to delete, then press 'shift', then press 'left click' on mouse/touchpad and start dragging down upto the last object you want to delete, than release the 'left click'. All those objects covered in drag will be selected !
Elin
Post by Elin »
I understand.
Thank you very much~
