Collisions leads to model "exploding"
mthor13
Contact:
Post by mthor13 » 28 Jan 2020, 15:10
Hi everyone,
As shown in the video below, I have had a problem for some time with a set of collisions leading the model blowing up.
I am using the Vortex Dynamic Engine and CoppeliaSim v. 4.0.0 (rev. 1).
Does anyone know if this is fixable?
Best Regards,
Mathias Thor
mthor13
Contact:
Re: Collisions leads to model "exploding"
Post by mthor13 » 28 Jan 2020, 15:53
So apparently all I needed to do was to post the question in here :)
In other words, I found the answer to the problem my self. If anyone else faces this issue, then try to adjust/reduce Vortex's "Contact tolerance [m]". I changed mine to 1.0000e-10 from 1.0000e-03.
Maybe this should be changed so that it per default is smaller in future CoppeliaSim versions?
Best Regards,
Mathias Thor
Never mind - the above solution only made the problem appear less frequently (so not fixed).
Post by coppelia » 28 Jan 2020, 15:54
Hello Mathias,
that is strange. It seems that, for some reason, one leg is landing under the floor, and this situation can't be salvaged. What happens if you simply use a floor with a much larger thickness?
mthor13
Contact:
Post by mthor13 » 28 Jan 2020, 16:04
Hi Coppelia,
Making the floor thicker helped and it doesn't happen as frequently any more - but it still happens.
It never happens when the hexapod is not colliding with anything else. It almost seems like it cannot handle all of the collisions.
Post by coppelia » 29 Jan 2020, 09:45
From what I can see you modelled the feet with a primitive sphere (i.e. pure sphere) and the floor/obstacles are primitive cuboids? If not, make at least sure that those shapes are convex.
Also, you could try to explore the many material properties available with the Vortex engine (e.g. skin thickness?)
mthor13
Contact:
Post by mthor13 » 03 Feb 2020, 12:59
I played a bit with the vortex engine material properties and found that my problem could be fixed by increasing the compliance of the materials :)
Best Regards,
Mathias Thor
Post by coppelia » 04 Feb 2020, 06:44
Thanks for the precision Mathias!
