Stop Window Maximizing During Scene Reset
Tamir
Post by Tamir » 05 Feb 2020, 09:16
For my uses, I have to reset the scene many times. Every time VREP resets, it pushes itself to the top window, even if it was minimized before.
Does anyone know how to suppress this?
Re: Stop Window Maximizing During Scene Reset
Post by coppelia » 05 Feb 2020, 15:11
what does reset mean for you? Stop a running simulation? Or start a new simulation run?
Also, what platform are you on?
Tamir
Post by Tamir » 06 Feb 2020, 07:16
Hello, thanks for the reply.
By reset, I mean stopping the scene and then starting it back up (with everything reset to initial conditions).
I have the newest version of CopelliaSim but I also faced the same behavior with the newest version of VREP. The computer is Linux.
Post by coppelia » 06 Feb 2020, 09:04
I cannot reproduce this. It must be something in your scene that is causing this... maybe a custom UI?
What happens if you use following code in a customization script, in an empty scene:
function sysCall_actuation()
    printToConsole(".")
    if sim.getSimulationTime()>20 and not stopping then
        stopping=true
        sim.stopSimulation()
        printToConsole("stopping")
function sysCall_afterSimulation()
    stopping=false
    printToConsole("starting")
    sim.startSimulation()
start your simulation then minimize the CoppeliaSim window. Does the window pop open again?
Tamir
Post by Tamir » 07 Feb 2020, 07:12
Using your customized script, the window doesn't maximize either.
I am using the remote API for python, for which it does. I am not using a customized UI to the best of my knowledge.
Edit: I noticed it does not occur with an empty scene or even with just a sphere
It looks like it is connected to my scene. In my scene, I create a graph and have a vision sensor
Edit2: It appears to be the graph
Tamir
Post by Tamir » 07 Feb 2020, 08:34
"Visibile while simulation running" was checked, which caused this undesired behavior, in case anyone else has the same issue. I unchecked it and it appears to be okay now.
Post by coppelia » 11 Feb 2020, 14:42
Thanks for the precisions. It seems that I cannot reproduce this on Windows. But this is very probably linked to the custom UI of the graph activating itself (in lua/utils.lua, around line 542, there is the activate argument).
