script communication
sampits
Post by sampits » 11 Feb 2020, 12:29
Ive been working with two script one move a conveyer depending on the proximity sensor state and for that i used the syscall_sensing() function.
Now i want to go there with my robot but i can seem to be able to communicate between the scripts since the sensordetection variable doesnt work outside of the function syscall_sensing or so i think.
Any ideas on how i can call that function on the robot script?
Re: script communication
Post by coppelia » 11 Feb 2020, 15:02
you have many different ways to share information between scripts or the outside world. Signals are probably the easiest.
sampits
Post by sampits » 11 Feb 2020, 15:56
now i have a different problem, when i pass a 0 to the conveyer it runs and when i pass a 1 it stops, even tough it works, when i am in 0 it doesnt change to 1 and when i am in 1 it doesnt change to 0 its weird to explain but what im trying to say is that once it is in a a state it doesnt change to other.(doesnt update the state)
   teste=sim.getFloatSignal("ok")
    if teste==0 then
        beltVelocity=sim.setFloatSignal("conveyorBeltVelocity",0.05)
    if teste==1 then
        beltVelocity=sim.setFloatSignal("conveyorBeltVelocity",0)
sampits
Post by sampits » 11 Feb 2020, 17:01
coppelia wrote:
11 Feb 2020, 15:02
if teste==0 then
if teste==1 then
