How to get data in graph
I add a Graph in scene,and add a new data stream to record.Now I can see the curve about the data stream I added.The question is how can I get the data stream and save it?
Re: How to get data in graph
you can select the graph object, then [Menu bar --> File --> Export --> Selected graphs as CSV...]
Otherwise, you'll have to collect the data yourself in each simulation step, put it into a table, and save that table to file at the end of a simulation, for example.
