Reading joint angles using Ros
shadowzone
Post by shadowzone »
Hello i was trying to read joint angles using ros
First i created a topic in syscall init in a non-threaded child script after playing a bit with controlled with ros scene example
if simROS then
print("<font color='#0F0'>ROS interface was found.</font>@html")
ab1SensorTopicHandler=simROS.advertise('/'..'bc1sensortopic','std_msgs/Float32')
then tried to publish on this topic using the following code
function sysCall_sensing()
    a = {}
    rrhip=sim.getObjectHandle("bc1")
    value=sim.getJointPosition(rrhip)
    a[1]=value
    print(a[1])
    print(ab1SensorTopicHandler)
    simROS.publish(ab1SensorTopicHandler,value)
and i got the following error saying float 32 expected a table
Lua runtime error: [string "CHILD SCRIPT body_respondable"]:55: read__std_msgs__Float32: expected a table (simROS.publish @ 'RosInterface' plugin)
stack traceback:
    [C]: in function 'publish'
    [string "CHILD SCRIPT body_respondable"]:55: in function
so i defined a table and tried replacing "Value" in ros.pubblish with 'a[1]' and 'a' but i still get the same error
I'm fairly new to ros and lua
Re: Reading joint angles using Ros
shadowzone wrote: 23 Feb 2020, 14:36 Hello i was trying to read joint angles using ros
if simROS then
    a = {}
    a[1]=value
    print(a[1])
stack traceback:
std_msgs/Float32 needs a 'data' field. Change your code to:
    local msg={}
    msg.data=value
    simROS.publish(ab1SensorTopicHandler,msg)
shadowzone
fferri wrote: 24 Feb 2020, 09:44
if simROS then
    a = {}
    a[1]=value
    print(a[1])
stack traceback:
    local msg={}
    msg.data=value
thanks it works now ^^
