Error: Signal 11 for Coppelia4.0.0 on Ubuntu 18.04
xuehonghu
Post by xuehonghu » 17 Mar 2020, 15:54
hello, everyone,
I installed the Ubuntu 18.04 version Coppelia on Ubuntu 18.04.
However, when start the program in the terminal "./coppeliaSim.sh". It returned the following error information:
Loading the CoppeliaSim library...
Done!
Launching CoppeliaSim...
lib: 1
lic: 1
CoppeliaSim Edu V4.0.0. (rev. 4)
Add-on script 'simAddOnScript-addOnScriptDemo.lua' was loaded.
Add-on script 'simAddOnScript-b0RemoteApiServer.lua' was loaded.
Add-on script 'simAddOnScript_PyRep.lua' was loaded.
If CoppeliaSim crashes now, try to install libgl1-mesa-dev on your system:
OpenGL: VMware, Inc., Renderer: SVGA3D; build: RELEASE; LLVM;, Version: 3.3 (Compatibility Profile) Mesa 19.2.8
...did not crash.
Simulator launched.
Plugin 'Geometric': loading...
Plugin 'Geometric': load succeeded.
Plugin 'Assimp': loading...
Plugin 'Assimp': warning: replaced variable 'simAssimp'
Plugin 'Assimp': load succeeded.
Plugin 'BlueZero': loading...
Plugin 'Bwf': loading...
Plugin 'Bwf': load succeeded.
Plugin 'CodeEditor': loading...
Plugin 'CodeEditor': load succeeded.
Plugin 'Collada': loading...
Plugin 'CustomUI': loading...
Plugin 'CustomUI': warning: replaced variable 'simUI'
Plugin 'CustomUI': warning: replaced function 'simUI.insertTableRow@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.removeTableRow@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.insertTableColumn@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.removeTableColumn@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.setScene3DNodeParam@CustomUI'
Tue Mar 17 15:44:45 2020 - ERROR: Compiled with the flag for AVX but not supported by the CPU.
Error: signal 11:
libcoppeliaSim.so(_Z11_segHandleri+0x2b)[0x7f272a2ee0bb]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f272e23ef20]
libVxPlatform.so.2019.0(+0x2bba4)[0x7f26eae73ba4]
libVxPlatform.so.2019.0(_ZN2Vx8LogErrorEPKcz+0x9d)[0x7f26eae73fbd]
libVxPlatform.so.2019.0(+0x20b97)[0x7f26eae68b97]
/lib64/ld-linux-x86-64.so.2(+0x10733)[0x7f272f33b733]
/lib64/ld-linux-x86-64.so.2(+0x151ff)[0x7f272f3401ff]
/lib/x86_64-linux-gnu/libc.so.6(_dl_catch_exception+0x6f)[0x7f272e3672df]
/lib64/ld-linux-x86-64.so.2(+0x147ca)[0x7f272f33f7ca]
/lib/x86_64-linux-gnu/libdl.so.2(+0xf96)[0x7f272b5eef96]
How to address that?
Re: Error: Signal 11 for Coppelia4.0.0 on Ubuntu 18.04
Post by coppelia » 17 Mar 2020, 17:56
not sure about the reason why, but the Vortex plugin is the culprit. Removing libsimExtDynamicsVortex.so should solve the problem of the crash (but you won't be able to use the Vortex engine).
xuehonghu
Post by xuehonghu » 21 Mar 2020, 10:31
Thanks for the answer! It works. But I wonder if deactivating vortex engine, what kind of function loss will I experience? Will slow down the simulation speed?
Post by coppelia » 26 Mar 2020, 08:50
You simply won't be able to use the Vortex engine for dynamics simulations. You'll have to use the Bullet, ODE or Newton engine instead.
