Rotate table
sampits
Rotate table
Post by sampits » 19 Mar 2020, 17:42
So i have this table and after the robot puts down a frame i need to rotate it so the people can reach it, does someone know how to rotate a table?
I saw there are motor in coppelia but they seem kinda weird but ill give it a try if it comes to it but is there a function that rotates objects ?
Re: Rotate table
Post by fferri » 23 Mar 2020, 11:00
Joint can do rotation.
sampits
Re: Rotate table
Post by sampits » 02 Apr 2020, 13:34
fferri wrote:
23 Mar 2020, 11:00
can i turn the table into a joint so i can rotate it ?
shadowzone
Re: Rotate table
Post by shadowzone » 02 Apr 2020, 13:38
you can make the table a child to a rotating joint and rotate the joint, since the table is a child of the joint it will rotate with it
