Thank you for your feedback. Which IDE d you use to develop plugin? Is visual Studio fitting well? Do I need Qt to do so?
Thank you,
Develop plugin for Coppelia Sim using LibPlugin
Re: Develop plugin for Coppelia Sim using LibPlugin
I would go with Qt, since this is cross platform and also what we are using.
You use Qt on windows or linux? Because Qt on windows is not free (and really expensive btw).
Best regards,
Best regards,
Qt for Open Source development is free and available for all platforms.
I downloaded Qt open source and open the simExtPluginSkeleton source code projet. I compiled it and it worked fine. Then I copied the generated .dll file into the CoppeliaSim installation folder. But when I run CoppeliamSim, the plugin is not loaded and I see this error:
Best regards,
Florent Pausé
Do I need to configure the build process? Which compiler do you use? I use Qt 5.14.1 MinGW 32-bit and 64-bit. Does it matter?Error with plugin 'PluginSkeleton': load failed (could not load). The plugin probably couldn't load dependency libraries. Try rebuilding the plugin.
Best regards,
Florent Pausé
Best is to use the same Qt version (if possible), and the same compiler as CoppeliaSim. Those requirements can be loosen depending on your plugin's functionality (is it using Qt functions at all?). If you are not using any Qt functionality, then it shouldn't really matter, since the CoppeliaSim API is a pure C API.
Check if there are missing dependencies for your plugin. Use the dependency walker (or the rewrite and newer version of it), if on Windows.
