Hi all,
My robot model joint was breaking apart,
I could not find any solution about it,
But, recently I have discovered that breaking apart joint has dummy connection,
I have tested it by changing place of dummy connection in tree.
So, why dummy connection breaks apart and what should I do to prevent it?
Dummy joint break apart
Re: Dummy joint break apart
Not sure what you mean with breaking apart. Maybe make sure you read the design considerations considerations 6-8 on the Designing dynamic simulations page.
You can see in below link a part of my design,
In my design, there are close loop mechanism,
Because of that I use dummy,
The place which I use dummy, breaks, as you can see in link.
In another joints there are not any break
Dittocoppelia wrote: ↑30 Mar 2020, 10:09 make sure you read the design considerations considerations 6-8 on the Designing dynamic simulations page.
