Nick_Name
Post
by Nick_Name »
after building the ROS2 Interface in my ros2_ws with custom messages (added in /meta) and starting it in Coppelia, I receive the following error:
Failed to find library 'custom_msgs__rosidl_typesupport_fastrtps_cpp'
double free or corruption (out)
./coppeliaSim.sh: line 33: 20197 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
Even though I can find the file
libcustom_msgs__rosidl_typesupport_fastrtps_cpp.so
in ros2_ws/build and ros2_ws/install/custom_msgs/lib
What am I missing?
BR Nick
Post
by fferri »
Did you source the ROS2 environment prior to starting CoppeliaSim?
Nick_Name
Post
by Nick_Name »
yes I sourced the environment beforehand with
Post
by fferri »
Then it is a ROS2 issue.
What is your platform and ROS2 version?
