Noisy acceleroemter measurement?
The accelerometer is fixed on the robot with axes aligned with the world coordinate. When the robot is moving straight along x axis, the measurement of the accelerometer is very noisy, its acceleration on y-axis obtains the same magnitude as on x-axis. Is there any setting about the noise?
Re: Noisy acceleroemter measurement?
there is no noise added directly. If there is noise, then it comes directly from the physics engine. Check if all physics engines produce similar noise.
