Gyrosensor and Python
LeafTeaNeko
Post by LeafTeaNeko »
Python version: 3.7
Hello, I am new at V-REP. I want to use the gyro sensor and accelerometer with python. In CoppeliaSim, I have the Gyro Sensor and accelerometer with its default script attached to my robot. I start and run the simulation from CoppeliaSim and the python script simply reads incoming data.
I've tired to follow along other examples listed in the forums and this is my script attached to gyrosensor
    modelBase=sim.getObjectAssociatedWithScript(sim.handle_self)
    ref=sim.getObjectHandle('GyroSensor_reference')
    ui=simGetUIHandle('GyroSensor_UI')
    simSetUIButtonLabel(ui,0,sim.getObjectName(modelBase))
    gyroCommunicationTube=sim.tubeOpen(0,'gyroData'..sim.getNameSuffix(nil),1)
    oldTransformationMatrix=sim.getObjectMatrix(ref,-1)
    lastTime=sim.getSimulationTime()
function sysCall_cleanup()
function sysCall_sensing()
    local transformationMatrix=sim.getObjectMatrix(ref,-1)
    local oldInverse=simGetInvertedMatrix(oldTransformationMatrix)
    local m=sim.multiplyMatrices(oldInverse,transformationMatrix)
    local euler=sim.getEulerAnglesFromMatrix(m)
    local currentTime=sim.getSimulationTime()
    gyroData={0,0,0}
    local dt=currentTime-lastTime
    if (dt~=0) then
        gyroData[1]=euler[1]/dt
        gyroData[2]=euler[2]/dt
        gyroData[3]=euler[3]/dt
    sim.tubeWrite(gyroCommunicationTube,sim.packFloatTable(gyroData))
    simSetUIButtonLabel(ui,3,string.format("X-Gyro: %.4f",gyroData[1]))
    simSetUIButtonLabel(ui,4,string.format("Y-Gyro: %.4f",gyroData[2]))
    simSetUIButtonLabel(ui,5,string.format("Z-Gyro: %.4f",gyroData[3]))
    oldTransformationMatrix=sim.copyMatrix(transformationMatrix)
    lastTime=currentTime
function getGyroData(inInts,inFloats,inStrings,inBuffer)
    return {},gyroData,{},''
and this is my python code:
import sim as vrep
vrep.simxFinish(-1)
clientID = vrep.simxStart('127.0.0.1', 19999, True, True, 5000, 5)
ERRORCODE, gyroRef = vrep.simxGetObjectHandle(clientID,'GyroSensor#0',vrep.simx_opmode_blocking)
if clientID != -1:
    ERRORCODE, gyro_data = vrep.simxGetFloatSignal(clientID, gyroRef, vrep.simx_opmode_streaming)
    while vrep.simxGetConnectionId(clientID) != -1:
        ERRORCODE, gyro_data = vrep.simxGetFloatSignal(clientID, gyroRef, vrep.simx_opmode_buffer)
	print(gyro_data)
else:
    vrep.simxFinish(clientID)
However I get the following error:
File "C:\Users\XXXX\Desktop\py-vrep\python-vrep.py", line 27, in <module>
File "C:\Users\XXXX\Desktop\py-vrep\sim.py", line 948, in simxGetFloatSignal
return c_GetFloatSignal(clientID, signalName, ct.byref(signalValue), operationMode), signalValue.value
ArgumentError: argument 2: <class 'TypeError'>: wrong type
A sample script that prints the data from gyro and accelerometer in python using the Remote API would be helpful to me. I tried to follow along the post https://forum.coppeliarobotics.com/viewtopic.php?t=8233 but the b0 API is not working for some reason.
I get the same errors as in the post, I edited the b0RemoteApi.py as suggested but that did not help either. I looked around the internet for possible answers but apparently this issue is persistent with python version lower than 3.8.
Answers similar to the post: https://forum.coppeliarobotics.com/vie ... yro#p33065 and would be incredibly helpful.
Thank you for your time and understanding, have a good day.
Edit: I've looked around and I've found a simxcallscriptfunction that I can use from python, Does that mean If I have a script in my simulation which prints all the values of accel and gryo sensor, I could essentially skip all the legwork and directly get the values from script?
Re: Gyrosensor and Python
sorry for the late reply. Yes, simxCallScriptFunction is basically what you would want to use, that simplifies things a lot. Just make sure that the called script function doesn't block. Typically you will call simple function inside of it, and return data. The simxCallScriptFunction can also be called in a streaming fashion, so that you can constantly retrieve data from that function, without having to call it constantly.
LeafTeaNeko
Hello Coppeliateam, thank you for the response.
I have 5 gyros and 5 accelormeters and this script is attached to a random cuboid in my scene.
Will something like this work?
    -- do some initialization here
    simRemoteApi.start(19999)
  sim.clearStringSignal('stringname')
   s=0
    lastReceivedFX=-1
    lastReceivedPos=-1
function sysCall_actuation()
packedFX=sim.getStringSignal('stringname')
            if packedFX then
                packedFX=sim.unpackFloatTable(packedFX)
           x1=packedFX[1]
           y1=packedFX[2]
           angle1=packedFX[3]
           x2=packedFX[4]
           y2=packedFX[5]
           angle2=packedFX[6]
           x3=packedFX[7]
           y3=packedFX[8]
           angle3=packedFX[9]
           x4=packedFX[10]
           y4=packedFX[11]
           angle4=packedFX[12]
           x5=packedFX[13]
           y5=packedFX[14]
           angle5=packedFX[15]
           packedFX1={x1,y1,angle1}
           packedFX2={x2,y2,angle2}
           packedFX3={x3,y3,angle3}
           packedFX4={x4,y4,angle4}
           packedFX5={x5,y5,angle5}
           sim.setStringSignal("copysignal",sim.packFloatTable(packedFX1))
           sim.setStringSignal("copysignal#0",sim.packFloatTable(packedFX2))
           sim.setStringSignal("copysignal#1",sim.packFloatTable(packedFX3))
           sim.setStringSignal("copysignal#2",sim.packFloatTable(packedFX4))
           sim.setStringSignal("copysignal#3",sim.packFloatTable(packedFX5))
  --accuring gyro and acc data
     local data=sim.getStringSignal("myGyroData")
if data then
    gyroData=sim.unpackFloatTable(data)
    g1=gyroData[1]
     g2=gyroData[2]
     g3=gyroData[3]
     local data=sim.getStringSignal("myaccData")
if data then
    accelData=sim.unpackFloatTable(data)
    a1=accelData[1]
    a2=accelData[2]
    a3=accelData[3]
      local data=sim.getStringSignal("myGyroData#0")
if data then
    g4=gyroData[1]
     g5=gyroData[2]
     g6=gyroData[3]
     local data=sim.getStringSignal("myaccData#0")
if data then
    a4=accelData[1]
    a5=accelData[2]
    a6=accelData[3]
     local data=sim.getStringSignal("myGyroData#1")
if data then
    g7=gyroData[1]
     g8=gyroData[2]
     g9=gyroData[3]
     local data=sim.getStringSignal("myaccData#1")
if data then
    a7=accelData[1]
    a8=accelData[2]
    a9=accelData[3]
 local data=sim.getStringSignal("myGyroData#2")
if data then
    g10=gyroData[1]
     g11=gyroData[2]
     g12=gyroData[3]
     local data=sim.getStringSignal("myaccData#2")
if data then
    a10=accelData[1]
    a11=accelData[2]
    a12=accelData[3]
 local data=sim.getStringSignal("myGyroData#3")
if data then
    g13=gyroData[1]
     g14=gyroData[2]
     g15=gyroData[3]
     local data=sim.getStringSignal("myaccData#3")
if data then
    a13=accelData[1]
    a14=accelData[2]
    a15=accelData[3]
   packetgyroandacc={g1,g2,g3,g4,g5,g6,g7,g8,g9,g10,g11,g12,g13,g14,g15,a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a11,a12,a13,a14,a15}
 -- px={g1,g2,g3,g4,g5,g6}
print(packetgyroandacc)
sim.setStringSignal("packetgyroandacc",sim.packFloatTable(packetgyroandacc))
return packetgyroandacc
    -- put your sensing code here
    -- do some clean-up here
and python code would be
import sim as vrep
vrep.simxFinish(-1)
if clientID != -1:
	returnCode, outFloats=simxCallScriptFunction(clientID, cuboid, vrep.sim_scripttype_childscript, 'sysCall_actuation',vrep.simx_opmode_blocking)
	print(outFloats)
else:
no this will not work: you should not call a system callback function (e.g. sysCall_actuation) from an external application. Create your own function and have that function collect and return the data you wish.
Typically, read your sensor data in the sensing callback script (sysCall_sensing), and make it available to your own script: your script function will simply return what was previously read via the sensing callback function.
Of course, you could also directly read the string signals from Python (simxGetStringSignal) and decode them with simxUnpackFloats.
LeafTeaNeko
THANK YOU SO MUCH! simxGetStringSignal and simxUnpackFloats works flawlessly. That was way simpler than I thought, I was doing something entirely unnecesssary. Thank you again CoppeliaSim team, have yourself a great day!
The problem was that our project was a collabarative effort and I'm not on the team that works on Coppeliasim, I simply use the data they send over in python and run them through a couple filters. As a sidenote, Does CoppeliaSim have a wiki for sample codes for sensors in python? or Would you guys be intrested in user-made scripts submitted to said wiki?
we don't yet have a wiki, but are always happy to get code snippets, models, scenes, etc. that we try to integrate into the user manual and/or next release.
