How to detect line using RemoteAPI
Posted: 18 May 2020, 13:20
by renyee95
Hi, I just start to learn CoppeliaSim last week. I wanted to use RemoteAPI in C language for controlling the line follower robot in CopeliaSim. Currently, my problem is unable to detect the black line on the ground. I able to connect to the vision sensor in CoppeliaSim using simxGetObjectHandle and simxReadVisionSensor both return values are simx_return_ok (0). But, I was unable to detect the black line on the floor in CoppeliaSim.
Is there any suggestion or ways to do line detection through RemoteAPI? Thank you.
Below is my code.
#include <Windows.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <extApi.h>
int main()
    bool VERBOSE = true;
    int clientID = 0;
    //ROBOT
    int leftmotorHandle = 0;
    int rightmotorHandle = 0;
    //LIGHT SENSOR
    int leftS = 0;
    int midS = 0;
    int rightS = 0;
    int vs = 0;
    float* auxValues;
    int* auxValuesCount;
    bool WORK = true;
    simxFinish(-1);
    clientID = simxStart((simxChar*)"127.0.0.1", 19000, true, true, 5000, 5);  //!< Main connection to V-REP
    Sleep(1000);
    if (clientID != -1)
        printf(" Connection status to VREP: SUCCESS \n");
        simxInt syncho = simxSynchronous(clientID, 1);
        int start = simxStartSimulation(clientID, simx_opmode_oneshot_wait);
        int TEST1 = simxGetObjectHandle(clientID, "DynamicLeftJoint", &leftmotorHandle, simx_opmode_oneshot_wait);
        int TEST2 = simxGetObjectHandle(clientID, "DynamicRightJoint", &rightmotorHandle, simx_opmode_oneshot_wait);
        int SENSOR_L = simxGetObjectHandle(clientID, "LeftSensor", &leftS, simx_opmode_oneshot_wait);
        int SENSOR_M = simxGetObjectHandle(clientID, "MiddleSensor", &midS, simx_opmode_oneshot_wait);
        int SENSOR_R = simxGetObjectHandle(clientID, "RightSensor", &rightS, simx_opmode_oneshot_wait);
        int sensorReadingL = simxReadVisionSensor(clientID, leftS, 1, &auxValues, &auxValuesCount, simx_opmode_oneshot_wait);
        int sensorReadingM = simxReadVisionSensor(clientID, midS, 1, &auxValues, &auxValuesCount, simx_opmode_oneshot_wait);
        int sensorReadingR = simxReadVisionSensor(clientID, rightS, 1, &auxValues, &auxValuesCount, simx_opmode_oneshot_wait);
        if (VERBOSE)
            printf("Computed object handle: %d \n", TEST1);
            printf("%d \n ", leftmotorHandle);
            printf("Computed object handle: %d ", TEST2);
            printf("%d \n ", rightmotorHandle);
        while (simxGetConnectionId(clientID) != -1 && WORK)
            simxSetJointTargetVelocity(clientID, leftmotorHandle, 5, simx_opmode_oneshot_wait);
            simxSetJointTargetVelocity(clientID, rightmotorHandle, 5, simx_opmode_oneshot_wait);
            printf("%d ", sensorReadingL);
            printf("%d ", sensorReadingM);
            printf("%d ", sensorReadingR);
            if (sensorReadingL == false ) //turn left
                simxSetJointTargetVelocity(clientID, rightmotorHandle, 8, simx_opmode_oneshot_wait);
                Sleep(1000);
            else if (sensorReadingR == false  ) //turn right
                simxSetJointTargetVelocity(clientID, leftmotorHandle, 8, simx_opmode_oneshot_wait);
                Sleep(1000);
        //simxPauseCommunication(clientID, 0);
        printf("Connection status to VREP: FAILED");
    simxFinish(clientID);
    return clientID;
Re: How to detect line using RemoteAPI
Posted: 22 May 2020, 10:48
sorry for the late reply.
In your program you are actually only reading the sensors once, at the program start. You need to read the sensors in your while loop, as you do with setting motor velocities.
You can use the blocking operation mode (as you do), but that will be quite slow. Typically you would use that mode for retrieving object handles, and when you need to wait for data from CoppeliaSim before going on.
But when just sending data to CoppeliaSim (e.g. setting motor velocities), use a non-blocking mode (simx_opmode_oneshot), and when streaming data, use simx_opmode_streaming and simx_opmode_buffer.
Make sure to carefully read more about those modes on this page.
Posted: 28 May 2020, 09:35
by renyee95
Hello
Thank you for your reply.
#include <stdio.h>
#include <stdlib.h>
#include <extApi.h>
int main()
    int clientID = 0;
    //ROBOT
    //LIGHT SENSOR
    int leftS = 0;
    int midS = 0;
    int rightS = 0;
    float* auxValues;
    int AA;
    int BB;
    //wheel detail
    float nominalLinearVelocity = 0.3;
    float wheelRadius = 0.027;
    float interW_distance = 0.119;
    double s = 1.0;
    bool WORK = true;
    simxFinish(-1);
    Sleep(1000);
    if (clientID != -1)
        int start = simxStartSimulation(clientID, simx_opmode_blocking);
        int LM = simxGetObjectHandle(clientID, "DynamicLeftJoint", &leftmotorHandle, simx_opmode_oneshot_wait);
        int RM = simxGetObjectHandle(clientID, "DynamicRightJoint", &rightmotorHandle, simx_opmode_oneshot_wait);
        int SENSOR_L = simxGetObjectHandle(clientID, "LeftSensor", &leftS, simx_opmode_blocking);
        int SENSOR_M = simxGetObjectHandle(clientID, "MiddleSensor", &midS, simx_opmode_blocking);
        int SENSOR_R = simxGetObjectHandle(clientID, "RightSensor", &rightS, simx_opmode_blocking);
        printf("Computed object handle: %d \n", LM);
        printf("Computed object handle: %d ", RM);
        char sensorReading[] = { false, false,false };
        sensorReading[0] = (simxReadVisionSensor(clientID, leftS, NULL, NULL, NULL, simx_opmode_streaming) == 1);
        sensorReading[1] = (simxReadVisionSensor(clientID, midS, NULL, NULL, NULL, simx_opmode_streaming) == 1);
        sensorReading[2] = (simxReadVisionSensor(clientID, rightS, NULL, NULL, NULL, simx_opmode_streaming) == 1);
            sensorReading[0] = (simxReadVisionSensor(clientID, leftS, NULL, NULL, NULL, simx_opmode_buffer));
            sensorReading[1] = (simxReadVisionSensor(clientID, midS, NULL, NULL, NULL, simx_opmode_buffer));
            sensorReading[2] = (simxReadVisionSensor(clientID, rightS, NULL, NULL, NULL, simx_opmode_buffer));
            double linearVelocityLeft = nominalLinearVelocity * s;
            double linearVelocityRight = nominalLinearVelocity * s;
            if (sensorReading[0] == false)
                linearVelocityLeft = linearVelocityLeft * 0.3;
            else if (sensorReading[2] == false)
                linearVelocityRight = linearVelocityRight * 0.3;
            simxSetJointTargetVelocity(clientID, leftmotorHandle, linearVelocityLeft / (s * wheelRadius), simx_opmode_oneshot);
            simxSetJointTargetVelocity(clientID, rightmotorHandle, linearVelocityLeft / (s * wheelRadius), simx_opmode_oneshot);
    return clientID;
I do it like this. Still unable to read the line on the ground. Is there anything wrong?
Please help me.
Thank you very much.
Posted: 29 May 2020, 06:55
Make sure you understand well how the legacy remote API works. In particular, simxReadVisionSensor
To prepare a vision sensor read for streaming, you would do something like:
unsigned char detectionState;
simxReadVisionSensor(clientID,leftS,&detectionStateLeft,NULL,NULL,simx_opmode_streaming);
To read data from that data stream, you would do something like:
int res=simxReadVisionSensor(clientID,leftS,&detectionStateLeft,NULL,NULL,simx_opmode_streaming);
if (res==0)
    // We have received a value. We can evaluate detectionStateLeft
Posted: 30 May 2020, 02:14
by renyee95
Finally, I got it.
Thank you very much for your patience in teaching me.
