We are currently using RGB-D cameras like the Intel RealSense D435 and use the depth channel to produce a point cloud. We would like to use CoppeliaSim to simulate a robot with a similar sensor.
Is it possible to create or modify a sensor?
Thank you.
Create/Modify Sensor
Re: Create/Modify Sensor
yes, you can create an modify any sensor or existing model. You can do simple things like combining various scene objects (e.g. shapes, sensors, joints, etc), write script-based controllers for them, or do sensor fusion (e.g. combine vision sensors with proximity sensors, or others), read out and combine those sensor data inside of a script. But you can also do more complex things via a plugin, that will allow you to create custom script callback functions that can help you implement high-level functionality.
Thank you for your response. Is there a tutorial available? How do you suggest I move forward if I am not too familiar with sensors and plugins in CoppeliaSim?
