How to control User Parameter in another Script?
Shaoxiang Wang
Post by Shaoxiang Wang »
i want to control the User Parameter of "suctionPad" in the script of "Target Dummy". So at the end of the Path, the User Parameter is changed to "false". Then the cylinder can fall.
But it's not successful. In "Target" script i used function
suctionPad= sim.getObjectHandle("suctionPad")
suctionPadScript = sim.getScriptAssociatedWithObject(suctionPad)
sim.setUserParameter(suctionPadScript,"active","false")
But error comes. It says "Object does not exist. (sim.setUserParameter)"
best regards
Shaoxiang
    -- do some initialization here
-- Get handles and postions of dummies
    tip = sim.getObjectHandle("tip")
    ownHandle = sim.getObjectHandle("Target")
    startPath1=sim.getObjectHandle("Path1_1")
    startPath2=sim.getObjectHandle("Path1_2")
    mittelPath1=sim.getObjectHandle("Path2_1")
    mittelPath2=sim.getObjectHandle("Path2_2")
    endPath1=sim.getObjectHandle("Path3_1")
    endPath2=sim.getObjectHandle("Path3_2")
    pathLength1=sim.getPathLength(startPath1)
    pathLength2=sim.getPathLength(startPath2)
    pathLength3=sim.getPathLength(mittelPath1)
    pathLength4=sim.getPathLength(mittelPath2)
    pathLength5=sim.getPathLength(endPath1)
    pathLength6=sim.getPathLength(endPath2)
    speed= sim.getUserParameter(sim.handle_self,'speed')-- end-effector velocity in m/s
    sim.setUserParameter(ownHandle,'@enable','')
    timestep=sim.getSimulationTimeStep() -- in s
    currentPositionRelative1=0
    currentPositionRelative2=0
    currentPositionRelative3=0
    currentPositionRelative4=0
    currentPositionRelative5=0
    currentPositionRelative6=0
    moveForward=true
    epsilon1=0.01
    epsilon2=0.01
    epsilon3=0.01
    epsilon4=0.01
    epsilon5=0.01
    epsilon6=0.01
function sysCall_threadmain()
    -- Put some initialization code here
    slowerWork=sim.getStringSignal("slowerWork")
    if slowerWork=="1" then
        slowerWork=true
        slowerWork=false
    -- path1
    if not slowerWork then
        pathAdvanceAbsolute=speed*timestep -- in m
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength1
        if currentPositionRelative1 < 1-epsilon1 and moveForward then
            currentPositionRelative1=currentPositionRelative1+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(startPath1,currentPositionRelative1)
            pathOrientation=sim.getOrientationOnPath(startPath1,currentPositionRelative1)
            objectPositionIsSet = sim.setObjectPosition(ownHandle,-1,pathPosition)
            objectOrientationIsSet = sim.setObjectOrientation(ownHandle,-1,pathOrientation)
        pathAdvanceAbsolute=0.2*speed*timestep -- in m
    -- path2
    if currentPositionRelative1 >= 1-epsilon1 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength2
        if currentPositionRelative2 < 1-epsilon2 and moveForward then
            currentPositionRelative2=currentPositionRelative2+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(startPath2,currentPositionRelative2)
            pathOrientation=sim.getOrientationOnPath(startPath2,currentPositionRelative2)
    -- path3
    if currentPositionRelative2 >= 1-epsilon2 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength3
        if currentPositionRelative3 < 1-epsilon3 and moveForward then
            currentPositionRelative3=currentPositionRelative3+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(mittelPath1,currentPositionRelative3)
            pathOrientation=sim.getOrientationOnPath(mittelPath1,currentPositionRelative3)
    -- path4
    if currentPositionRelative3 >= 1-epsilon3 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength4
        if currentPositionRelative4 < 1-epsilon4 and moveForward then
            currentPositionRelative4=currentPositionRelative3+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(endPath1,currentPositionRelative4)
            pathOrientation=sim.getOrientationOnPath(endPath1,currentPositionRelative4)
            currentPositionRelative4=currentPositionRelative4+pathAdvanceRelative
    -- path5
    if currentPositionRelative4 >= 1-epsilon4 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength5
        if currentPositionRelative5 < 1-epsilon5 and moveForward then
            currentPositionRelative5=currentPositionRelative5+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(endPath2,currentPositionRelative5)
            pathOrientation=sim.getOrientationOnPath(endPath2,currentPositionRelative5)
    -- path6
    if currentPositionRelative5 >= 1-epsilon5 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength6
        if currentPositionRelative6 < 1-epsilon6 and moveForward then
            currentPositionRelative6=currentPositionRelative6+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(mittelPath2,currentPositionRelative6)
            pathOrientation=sim.getOrientationOnPath(mittelPath2,currentPositionRelative6)
    if currentPositionRelative6 >= 1-epsilon6 then
function sysCall_cleanup()
    -- Put some clean-up code here
-- See the user manual or the available code snippets for additional callback functions and details
Re: How to control User Parameter in another Script?
Shaoxiang Wang wrote: 04 Jun 2020, 21:11 suctionPad= sim.getObjectHandle("suctionPad")
sim.setUserParameter wants an object handle. Try with sim.setUserParameter(suctionPad,"active","false")
Shaoxiang Wang
Thanks for your advice! Now it can work well.
