Error message from sim.convexDecompose
allen0413
Post by allen0413 »
As I try to do exact the same thing about this post,
https://forum.coppeliarobotics.com/view ... 037#p32037
It seems working fine, but still gives me an error message :
Lua runtime error: [string "CHILD SCRIPT Mike"]:7: Invalid argument. (sim.convexDecompose)
stack traceback:
[C]: in function 'convexDecompose'
[string "CHILD SCRIPT Mike"]:7: in function
Looks like it's something wrong with the parameters I gave to the sim.convexDecompose function? But I thought the parameters are exactly same as the post using...
https://imgur.com/LVGhCSg
Here's my code :
    repeat until (simRemoteApi.start(19996,1300,false,true)~=-1)
    mike1 = sim.getObjectHandle('Mike')
    tIntParams = {0, 0, 0, 0, 0, 100000, 20, 4, 4, 64}
    tFloatParams = {0.0, 0.0, 0.0, 0.0, 0.0, 0.002, 0.05, 0.05, 0.001, 0.0001}
    convex = sim.convexDecompose(mike1, 129, tIntParams, tFloatParams)
    print(convex)
Error occurs so it don't compile the codes after "convex = sim.convexDecompose(mike1, 129, tIntParams, tFloatParams)"
What's the problem?
allen0413
Re: Error message from sim.convexDecompose
Post by allen0413 »
Or is there anyway to simply just skip the error?
what CoppeliaSim version are you using? I can't reproduce your error.
To avoid errors triggering, you can do something like:
function protectedFunc(a,b,c,d)
    convex = sim.convexDecompose(a,b,c,d)
    return convex
    mike1 = sim.getObjectHandle('a')
    local res,convex=pcall(protectedFunc,mike1, 129, tIntParams, tFloatParams)
    if res then
        -- success
        -- Error happened in protectedFunc
