Computed Torque Controller
Essa6
Post by Essa6 »
I designed a computed torque controller for UR5 robot and i have a csv file that contains the values of torques for all joints for 100 iterations, the size of csv file is 100*6
I connect the python to vrep and i want to send torque values to vrep from python but the robot didn't respond to any value please i need help for my project, this is part of my code i made for loop 2D to iterate over the csv file :
sim.simxPauseCommunication(clientID, True)
for i in range(100):
    for j in range(6):
        sim.simxSetJointTargetVelocity(clientID, joint_handles[j],   10000000000, sim.simx_opmode_oneshot);
        sim.simxSetJointForce(clientID, joint_handles[j], taumat[i][j], sim.simx_opmode_oneshot)
sim.simxPauseCommunication(clientID, False)
I have another question, i made a trajectory generation for UR5 and the robot didn;t respond to any value
for j in range(6):
	sim.simxSetJointPosition(clientID, joint_handles[j], traj[i][j], sim.simx_opmode_oneshot)
Re: Computed Torque Controller
use something like following instead:
    for j in range(6):
    pause for a few ms
otherwise all 100x6 values will be sent at the same time and applied at the same time!
Make sure your joints are dynamically enabled, the motor is enabled and the control loop is disabled.
In your second problem, your joint should be in position control mode (motor enabled and control loop enabled too, in position control). Is this the case? Here too, you are almost sending instantaneously 100x6 values at once...
Essa6
Post by Essa6 »
Thank you very much, its work
