body = sim.getObjectHandle('SBR')
body_ort = sim.getObjectOrientation(body, -1)
sigma = body_ort[3]
I am using getObjectOrientation() to get robot's orientation around z-axis. Using matlab controller, I want the robot to turn from 0 to 360 deg and more but it seems like this function return angles in negative once the robot crosses 180 deg. Here is a plot:
I want to develop a code that would take the initial orientation of the robot as 0deg and increase the angle if SBR rotates counterclockwise and negative if SBR rotates clockwise.
Thanks in advance!
Good day,
Thank you very much for your post. That's what I thought. Unfortunately, my attempts of developing such an algorithm didn't succeed. Can you help me with that?
function sysCall_sensing()
local orientation=sim.getObjectOrientation(objectHandle,-1)
local newAngle=orientation[3]
local increment=newAngle-angle
while math.abs(increment)>math.pi*1.5 do
increment=increment*(1-2*math.pi/math.abs(increment))
angle=angle+increment
print(angle)
