Now I have planned a path by OMPL plugin in V-REP. After I looked up the CoppeliaSim helpFiles, I can't find any methods to get the length of a planned path returned by API function simOMPL.compute() not the length of a path object.
Please help me.
Thank you!
How can I compute and get the length of a path planned by OMPL plugin
Re: How can I compute and get the length of a path planned by OMPL plugin
There is no such function because the state space is customly defined.
In general it does not make sense to compute a length between poses, or between angles. You should be able to figure out a "good" length metric on your customly defined state space.
What state space are you using?
Perhaps the length of the path projected onto the default euclidean projection would work?
function simOMPL.getProjectedPathLength(taskHandle,path)
local m=simOMPL.projectionSize(taskHandle)
local pathProjection=simOMPL.projectStates(taskHandle,path)
local length=0
for i=2,#pathProjection/m do
local s=0
for j=1,m do
s=s+math.pow(path[i*m+j]-path[(i-1)*m+j],2)
length=length+math.sqrt(s)
return length
