configuration of the time in the case using remote API
dimsky
Re: configuration of the time in the case using remote API
Post by dimsky »
I am using version 4.1 to display dummy movement graphs in my simulation.
Now when I update to version 4.2 the hierarchy graph can't be found in my hierarchy scene. Please help so I can quickly solve this problem. because it concerns my final research project. can I use version 4.1 back as before? I think when I use version 4.2 it makes me have to study that version first, especially in Indonesia, I rarely find research references using Coppeliasim
please help, thank you
best regards
dimas tri saptaji
SitStudent
Post by SitStudent »
you can download the previous versions here.
https://www.coppeliarobotics.com/previousVersions
Additionally, you can enable old dialogs by setting showOldDlgs=true in system/usrset.txt
SitStudent
Hi
In the above code, is there any way to start a record when remoteAPI(regacy) is connected, and end it when it is disconnected?
try with following:
graph=require('graph_customization')
    graphHandle=sim.getObjectHandle(sim.handle_self)
    -- Create/update data streams/curves:
    sim.destroyGraphCurve(graphHandle,-1)
    stream1=sim.addGraphStream(graphHandle,'Object position X','m')
    objectHandle=sim.getObjectHandle('cube')
    graph.init()
    startMeasurement()
function startMeasurement()
    startTime=sim.getSystemTime()
    graph.reset()
    measure=true
function stopMeasurement()
    measure=nil
function appendMeasurementPts()
    if measure then
        -- append measurement points, e.g. the x-position of an object:
        local p=sim.getObjectPosition(objectHandle,-1)
        sim.setGraphStreamValue(graphHandle,stream1,p[1])
        graph.handle(sim.getSystemTime()-startTime)
        graph.updateCurves()
function sysCall_sensing()
function sysCall_nonSimulation()
function sysCall_suspended()
function sysCall_beforeSimulation()
function sysCall_afterSimulation()
function sysCall_suspend()
function sysCall_resume()
and call startMeasurement and stopMeasurement.
