only adding force on primatic_joint
Zhuang
Post by Zhuang »
only adding force on primatic_joint using
force = {u,0,0} --u is a variable
torque = {0,0,0}
sim.addForceAndTorque(CarHandle ,force, torque)
and then,
The object is spinning
Re: only adding force on primatic_joint
Sorry, is that a question? If yes, what exactly is the problem?
Zhuang
Post by Zhuang »
well, it is difficult to describe it. So there is the file(.ttt). the link is https://www.dropbox.com/s/y39f0bgfv3kgm ... m.ttt?dl=0
your motor is not dynamically enabled, it is in passive mode. You can notice that if you look at the scene hierarchy: there is no bouncing ball next to that joint. So set that joint into force/torque mode, disable its motor. And adjust its range to be large enough (e.g. [-2;+2] meters). Then, make sure that the car and the base are not colliding, otherwise you'll introduce friction. You can adjust that by slightly moving the car higher, or by change the respondable mask. Then it won't spin anymore.
And in that situation, instead of adding an external force, you could also simply enable the motor of the prismatic joint, and adjust its force with sim.setJointMaxForce.
Zhuang
Post by Zhuang »
According to your suggestion, I made the following changes:
1) the type of the joint Motor: setting positive model to force/torque mode
2) the motor enabled of the joint Motor: setting disable
3) the car's position: slightly moving the car higher
4) the friction factor: setting it to 0
However I can not control the joint Motor thought
if u > 0 then --u is the controlling force
   sim.setJointTargetVelocity(motorHandle, -100)
   sim.setJointTargetVelocity(motorHandle, 100)
sim.setJointMaxForce(motorHandle, math.abs(u))
the model's link is :https://www.dropbox.com/s/t35grb8yo31dc ... m.ttt?dl=0
you need to:
  • increase the range of your prismatic joint. Currently its limits are [-3;0] (i.e. pos. min is -3, pos. range is 3)
  • the prismatic joint motor needs to be enabled of course. Otherwise you can't control it. But keep the control loop of that joint disabled
