Hello guys,
We need to create a soccer table for a robotic simulation.
We create the part in SolidWorks and imported it to CoppeliaSim. unfortunately, the CoppeliaSim doesn't recognize the inside of the table(the table should be black) and the sketches on it.
What should i do in order to fix this issue?
i'm adding a photo of this case:
https://ibb.co/DtcTnPY
CoppeliaSim doesn't recognize depth
Re: CoppeliaSim doesn't recognize depth
you have imported a single shape. You can change the color for the entire shape. If you need more than one color for a single shape, then you need to decompose it into several sub-shapes. Later on you can group them together again.
Have also a look at the triangle edit mode.
Also, if your mesh that you import has several parts/colors/textures, then you can import it as is (Collada format (DAE)).
