simDisplayDialog fails when called in menuitem_selected
ysuga
Post by ysuga »
I am V-rep user and now I am planning to use CoppeliaSim in University research activities.
Before that, I must upgrade my own v-rep Ext plugin to the current CoppeliaSim, but I have a problem around showing dialog.
The plugin is written in C++, and registers some customized menu items in the "simStart" function (simAddModuleMenuEntry).
When I select the menu item, sim_message_eventcallback_menuitemselected message is captured in simMessage function, and I would like simulator to pop up an Input dialog.
if (message == sim_message_eventcallback_menuitemselected) {
  simInt handle = auxiliaryData[0];
  simInt state = auxiliaryData[1];
  if (handle == robotItemHandle) {
    std::cout << "My Menu Selected" << std::endl;
    dlgHandle = simDisplayDialog("Input Robot Item", "Input Robot Model Name", sim_dlgstyle_input, "", NULL, NULL, NULL);
The global scope variable named "dlgHandle" becomes 0, but the simulator indicates the following message:
[CoppeliaSim:error]   External call to simCallScriptFunction failed (sim.getDialogResult): Error in script function.
What is wrong? This routine was successful in V-rep. Please help me!
My environment:
IntelCPU PC + Windows 10 + Visual Studio 2017 (Compiled with x64)
CoppeliaSim 4.1.0 Edu
Re: simDisplayDialog fails when called in menuitem_selected
this is because we have reworked several part of the GUI. The sim_message_eventcallback_menuitemselected event is handled via the GUI thread. But you shouldn't normally call API functions via the GUI thread (that is still possible, but bad practice and might lead to similar problems in future). Instead, use a signal-slot mechanism to use the simulation thread, or a very simple way could also be something like:
SIM_DLLEXPORT void* simMessage(int message,int* auxiliaryData,void* customData,int* replyData)
    static bool showdlg=false;
    if (message==sim_message_eventcallback_menuitemselected)
        showdlg=true;
    if (message==sim_message_eventcallback_instancepass)
        if (showdlg)
            int dlgHandle = simDisplayDialog("Input Robot Item", "Input Robot Model Name", sim_dlgstyle_input, "", NULL, NULL, NULL);
            printf("dlgHandle: %i\n",dlgHandle);
            showdlg=false;
