sir,
I created a two link flexible manipulator in V-rep for my project. Now I want to measure the vibrations of that two links.
1)Can you please tell me is it possible to measure the vibrations generated in the flexible links? And, how can i measure this?
2)Is it possible to measure the vibrations generated in the flexible links using available sensors in V-rep? If yes, how?
vibration measurement of a flexible link
Re: vibration measurement of a flexible link
if you have e.g. a flexible beam emulated via two rigid beams linked together via a revolute joint in spring mode, then you can read the position of the joint: that will give you an idea of the vibration. Be aware that high-frequency vibrations can't be simulated effectively via those physics engines.
function sysCall_init()
handle=sim.getObjectHandle('myJointName')
function sysCall_sensing()
local v=sim.getJointPosition(handle)
print(string.format("Joint angle is %.1f[deg] at simulation time %i[ms]",v*180/math.pi,sim.getSimulationTime()*1000))
