Restarting the simulation from Matlab remote API
Rosuar
Post by Rosuar »
Hello, I'm pretty new with the software and I'm stuck on a problem:
I'm trying to make a simulation of a dynamic system that is affected by gravity, the problem that I have is that if I run the simulation and then start the matlab script, a part of my model falls down so I want to be able to restart the simulation based on the remote commands that I found:
sim.simxStopSimulation(clientID,sim.simx_opmode_blocking);
sim.simxStartSimulation(clientID,sim.simx_opmode_blocking);
What happens is that the simulation does stop, but won't start again, what am I doing wrong?
Thanks in advance.
Re: Restarting the simulation from Matlab remote API
try to put some pause between those two commands (or make sure to wait until the simulation has really stopped before restarting it): A stop message will simply trigger a stop procedure, that can take several simulation steps. So, even if your operation mode is blocking, when control returns to your Matlab client, the simulation hasn't stopped yet. If you immediately send a restart command, that might be ignored, since simulation hasn't yet stopped.
