OMPL Path Structure
sc18ldh
OMPL Path Structure
Post by sc18ldh »
I am looking at the 3DoFHolonomicPathPlanning scene and I am just trying to work out the structure of the path returned by OMPL.
Here is a snippet of the relevent code from the demo
    r,path=simOMPL.compute(t,4,-1,800)
    print(path)
    while path do
        visualizePath(path)
        -- Simply jump through the path points, no interpolation here:
        for i=1,#path-3,3 do
            pos={path[i],path[i+1],initPos[3]}
            orient={initOrient[1],initOrient[2],path[i+2]}
            sim.setObjectPosition(robotHandle,-1,pos)
            sim.setObjectOrientation(robotHandle,-1,orient)
            sim.switchThread()
My question is that as for pos x and y are set to path [ i] and path[i + 1] is the path returned by OMPL structured to be an alternating series of x and then y values?
And if so does this path representation change when selecting an alternate stateSpaceType such as dubins?
I apologise if I have missed some obvious documentation explaining this, thanks!
Re: OMPL Path Structure
The returned path is a sequence of states.
The length and content of a state depends on how the state space is defined:
  • if the state space is a single simOMPL.StateSpaceType.position2d, then the state is \(\left<p_x, p_y\right>\).
  • if the state space is a single simOMPL.StateSpaceType.pose2d (SE(2)), then the state is \(\left<p_x, p_y, \theta\right>\).
  • if the state space is a single simOMPL.StateSpaceType.position3d, then the state is \(\left<p_x, p_y, p_z\right>\).
  • if the state space is a single simOMPL.StateSpaceType.pose3d (SE(3)), then the state is \(\left<p_x, p_y, p_z, q_x, q_y, q_z, q_w\right>\).
  • if the state space is a single simOMPL.StateSpaceType.joint_position, then the state is \(\left<p\right>\).
  • if the state space is a single simOMPL.StateSpaceType.dubins (SE(2)), then the state is \(\left<p_x, p_y, \theta\right>\).
Where \(p_x\), \(p_y\), \(p_z\) are the x, y, z position, \(\theta\) is orientation on the (XY) plane, \(q_x\), \(q_y\), \(q_z\), \(q_w\) is the 3D orientation expressed as a unit quaternion, \(p\) is the value of a joint position.
If the state space is a composition of the above, simple concatenation applies, e.g.: if the state space consists of two components: 1) simOMPL.StateSpaceType.position2d and 2) simOMPL.StateSpaceType.joint_position, then the state is \(\left<p_x, p_y, p\right>\).
The path is simply the repetition of the n states, i.e. \(\left<{p_x}^{(1)}, {p_y}^{(1)}, {p}^{(1)}, {p_x}^{(2)}, {p_y}^{(2)}, p^{(2)}, \ldots, {p_x}^{(n)}, {p_y}^{(n)}, {p}^{(n)}, \right>\).
You can use simOMPL.getPathStateCount(taskHandle,path) to get the number of states from the returned path, and simOMPL.getPathState(taskHandle,path,index) to extract the state at position index.
sc18ldh
Post by sc18ldh »
That makes perfect sense, thank you for explaining it in such clear detail!
TrimItOut
Post by TrimItOut »
I have a question regarding the θ returned by the dubin’s state space.
As this is an orientation in the (xy) plane how would I get it into a format so that it can be used to set an object orientation using sim.setObjectOrientation?
As sim.setObjectOrientation is expecting a table of 3 Euler angles
Thanks in advance!
sim.setObjectOrientation(handle,-1,{0,0,theta})
TrimItOut
Post by TrimItOut »
Perfect!
