How to change the default settings?
elephant
Post by elephant »
Is possible to change for example, what script will embed when the user put a new robot on scene?
Re: How to change the default settings?
It is not clear what you are asking:
  • if you are asking how to change the embedded script of a specific model, simply add it to the scene, modify the script, and re-export the model
  • if you want a piece of script to be executed whenever some robot is added to the scene, then you can define a sysCall_afterCreate() function in an add-on script
elephant
Post by elephant »
fferri wrote: 22 Feb 2021, 11:45 It is not clear what you are asking:
Thanks!! thats helped me a lot. it solved my problem
