I want to know how the color of the laser line of the two-dimensional scanner LaserScanner_2D can be changed. Initially it is red, but I want green.
And how can you make the VisionSensor see the laser line?
https://clip2net.com/s/4bdy2Wp
Thank!
LaserScanner_2D
Re: LaserScanner_2D
in that model, and in CoppeliaSim version prior to V4.2.0, the laser is handled via a graph, which is actually not a very good idea. Anyway, you can modify the color of the 3D curve by selecting the graph, and in its properties dialog, click Edit 3D curve, select ScannerHits, then click Adjust color.
In the common section of the graph dialog, click Renderable, then it becomes also visible when seen from vision sensors.
