Set customized texture to compound shapes programmatically
cxt
Post by cxt »
As in the title, I want to set customized texture to compound shapes programmatically, which I found 'sim.setShapeTexture' didn't work (it worked perfectly on single shapes). I found 'quick texture' in simulator ui can work also but didn't find corresponding api. Do you have any suggestions without changing shape structure?
Re: Set customized texture to compound shapes programmatically
I think the best you can do is to ungroup the shape, apply the texture, the group it again. Have a look at sim.ungroupShape and sim.groupShape.
