Showing multiple poses in one figure?
w1574587
Post by w1574587 »
I want to show multiple poses in one figure as a manipulator moving along a trajectory. I've seen someone did it by plotting translucent poses but I don't know how. Is it possible within CoppeliaSim? Any other suggestions?
Re: Showing multiple poses in one figure?
Maybe sim.addGhost is what you are looking for.
w1574587
Post by w1574587 »
Exactly! Thanks a lot!
I would rather prefer you to use something like following, to generate a trace instance for a shape:
    local copy=sim.copyPasteObjects({originalObject},0)[1]
    local script=sim.getScriptAssociatedWithObject(copy)
    if script>=0 then
        sim.associateScriptWithObject(script,-1)
    sim.setObjectInt32Parameter(copy,sim.shapeintparam_static,1)
    sim.setObjectInt32Parameter(copy,sim.shapeintparam_respondable,0)
    sim.setObjectProperty(copy,sim.objectproperty_selectinvisible)
    sim.setObjectSpecialProperty(copy,sim.objectspecialproperty_renderable)
    sim.setShapeColor(copy,'',sim.colorcomponent_ambient_diffuse,{0,1,0})
    sim.setShapeColor(copy,'',sim.colorcomponent_transparency,{0.2})
If you have several shapes, use above for each shape, then group them with sim.groupShapes.
Then you have more control than with ghosts, and ghosts might not be supported in the same way in future releases or deprecated.
w1574587
Post by w1574587 »
Thank you for the suggestion! Now I have two new questions.
1) Why does the
sim.setShapeColor(copy,'',sim.colorcomponent_transparency,{0.5})
has no effect? The "fake" robot links are still not translucent.
2) I use MATLAB to control the robot. Anyway I followed your instruction and wrote a Lua script. Now I can only draw the initial pose. How can I draw the poses in the midterm?
FYI. Here is my Lua script.
repeat until (simRemoteApi.start(19999,1300,false,true)~=-1)
function showPose(handleName)
originalObject=sim.getObjectHandle(handleName)
if script>=0 then
showPose('UR5_link1_visible')
showPose('UR5_link2_visible')
showPose('UR5_link3_visible')
showPose('UR5_link4_visible')
showPose('UR5_link5_visible')
showPose('UR5_link6_visible')
showPose('UR5_link7_visible')
w1574587
Post by w1574587 »
Update:
Haven't figure out the transparency problem.
Here is my way to plot multiple poses. Looking forward to a more elegant solution...
-- lua
if script>=0 then
function showAllPose()
while (true)
do
timeNow=sim.getSimulationTime()
--print(timeNow)
if timeNow>0 and timeNow<0.04
then
showAllPose()
if timeNow>1.2 and timeNow<1.21
then
showAllPose()
if timeNow>1.7 and timeNow<1.71
then
showAllPose()
if timeNow>2.9 and timeNow<2.91
then
showAllPose()
w1574587 wrote:
22 Mar 2021, 04:25
1) Why does the
I cannot reproduce that. If I create a new shape in the scene, attach a child script to it and programmatically set its transparency, it appears transparent here. Maybe you can post a minimalistic, self-contained scene that illustrates that situation?
As to how to create a trace of a shape, at several time intervals: simply repeat to procedure each time x seconds have passed, e.g. from within a threaded child script:
    local shapesToTrack={...}
    local timeInterval=2
    while true do
        for i=1,#shapesToTrack,1 do$
            showPose(shapesToTrack[i])
        sim.wait(timeInterval)
w1574587
Post by w1574587 »
Thank you for the reply! Similarly, I added some shapes on the end-effector and the code worked. But for the UR5 manipulator, it doesn't work. The scene that illustrates that situation can be obtained by following steps:
1) open a new scene
2) drag and drop UR5.ttm into the scene
3) add threaded child script to UR5_link1_visible, the code:
-- Lua
function sysCall_threadmain()
if script>=0 then
    local shapesToTrack={"UR5_link1_visible","UR5_link2_visible","UR5_link3_visible","UR5_link4_visible","UR5_link5_visible","UR5_link6_visible","UR5_link7_visible"}
    while true do
        originalObject=sim.getObjectHandle("UR5_connection")
function sysCall_cleanup()
    -- Put some clean-up code here
4) run the simulation
Ok,
the model you mention has named colors. So instead of:
do
        sim.setShapeColor(copy,nil,sim.colorcomponent_ambient_diffuse,{0,1,0})
        sim.setShapeColor(copy,nil,sim.colorcomponent_transparency,{0.5})
Additionallyy it is probably a good idea to attach all created objects onto a dummy, so that the hierarchy keeps clean. And/or group those shapes on a regular interval, to avoid having too many of them. This should not be a problem since they are static anyway.
w1574587
Post by w1574587 »
Awesome! Many thanks!!
