About the terrain bump
yifanzhou
Post by yifanzhou »
I am using the model ——terrain bump.ttm. Is it possible to get the position information about the edge point of the terrain bump? As I show in the figure below.
Re: About the terrain bump
the data is generated in a generic manner, so you will have to identify where it is generated. In that attached customization script, near the end, you have the generation of the height field. You can modify the code to something like following, in order to visualize the individual points:
    local points={}
    local xSize=dxs
    local ySize=yt*dxs/xt
    local dx=xSize/xt
    local dy=ySize/yt
    for y=1,yt,1 do
        for x=1,xt,1 do
            xp=(x-xt/2)/(xt/2)
            yp=(y-yt/2)/(yt/2)
            r=dps*math.sqrt(t1*xp*xp+t2*yp*yp)
            nh=dzs/((r*r)+1)
            if (nh<minw) then minw=nh end
            if (nh>maxw) then maxw=nh end
            table.insert(heights,nh)
            local pos={-xSize*0.5+(x-1)*dx,-ySize*0.5+(y-1)*dy,nh}
            points[#points+1]=pos
    bumpShape=sim.createHeightfieldShape(options,0,xt,yt,dxs,heights)
    local c=sim.addDrawingObject(sim.drawing_spherepoints,0.02,0,-1,4)
    sim.setObjectName(bumpShape,objName)
    sim.setObjectProperty(bumpShape,objProperty)
    sim.setObjectSpecialProperty(bumpShape,objSpecialProperty)
    sim.setObjectParent(bumpShape,h,true)
    scaling=(maxw-minw)/(maxv-minv)
    matr[12]=matr[12]*scaling
    local oldM=sim.getObjectMatrix(bumpShape,-1)
    sim.setObjectMatrix(bumpShape,sim.handle_parent,matr)
    local newM=sim.getObjectMatrix(bumpShape,-1)
    if config.textured then
        sim.setShapeTexture(bumpShape,bumpTextureId,sim.texturemap_plane,4+8,{1,1})
        sim.setShapeColor(bumpShape,'',0,{1,1,1})
        sim.setShapeColor(bumpShape,'',sim.colorcomponent_ambient_diffuse,config.color)
    local drawingcontainer=sim.addDrawingObject(sim.drawing_spherepoints,0.002,0,-1,99999)
    sim.invertMatrix(oldM)
    local m=sim.multiplyMatrices(oldM,newM)
    for i=1,#points,1 do
        local p=sim.multiplyVector(m,points[i])
        sim.addDrawingObjectItem(drawingcontainer,p)
In the above loop, the corner points are generated when y==1 or y==yt and x==1 or x==xt.
