Collision object disappear
KKW
Post by KKW »
I found an object disappear problem when running simulation, it is as the video shows
if not reachable, here is the link
i have tested several times, the disappearing often occurs a period of time after they first collide.
According to a previous topic, i checked
  • mass varies from 1e-3 to 1 kg
  • principle moment of inertia/mass from 1e-6 to 1e-3,
  • force of the joint from 4 to 10 Nm
  • usingsim.getContactInfo to show force, maximum around 5-7N
have no clue why they disappear, is the stick to thin? the disappearing one in the video has mass 0.02kg, principle moment of inertia/mass 7e-4, 7e-4 and 7e-6.
Or should i reduce the simulation timestep? now is 3ms under ode engine.
the scene file is here
Thanks for any suggestion
Best Regards,
KKW
Re: Collision object disappear
objects disappearing are usually the result of the physics engine writing/computing bad values for object positions/orientations. In your case the objects that have disappeared have an illegal position (e.g. NaN, not a number). You can also provoke this by writing Nan-type values to object positions, inside of a script.
Try to monitor specific values to see if you get something funny just before an objects disappears (the object will however still be visible in the scene hierarchy).
