Handling OMPL exceptions
TrimItOut
Post by TrimItOut »
I was wondering if it would be possible within the sim to handle errors from OMPL without them bringing the simulator to a halt. Here is an example of errors that I am trying to handle
[simExtOMPL:warning] OMPL: e:\ompl-1.4.1-source\src\ompl\base\src\planner.cpp:310: RRTConnect: Skipping invalid goal state (invalid state)
[simExtOMPL:error] OMPL: e:\ompl-1.4.1-source\src\ompl\geometric\planners\rrt\src\rrtconnect.cpp:252: RRTConnect: Unable to sample any valid states for goal tree
This is a valid error and is occuring when I am trying to plan a path and the goal is obscured, is there any way that I can handle this or check for invalid states before running simOMPL.compute?
Cheers!
Re: Handling OMPL exceptions
not sure what you mean when you say a valid error...
But from the message the calculation cannot happen. So an exception is generated.
Now, if you want to catch an exception without an error to be generated, you can do something like:
function generateAnError()
    a=nil
    a=a+1
    local result,errorMsg=pcall(generateAnError)
    if not result then
        print("Error is: "..errorMsg)
TrimItOut
Post by TrimItOut »
Thanks for your response and your code example , this is exactly along the lines of what I'm looking for.
Would there be any way to handle this error if the function being tried (generateAnError in this case) has parameters and also returns a variable?
e.g. if the function does NOT throw an error then assign the variable otherwise result is set = false
As an example of what I'm trying to do
function generateAnError(number)
    a=nil
    a=a+1
    return number
    local result,errorMsg=pcall(return_number=generateAnError(2))
    if not result then
I know the code above has obviously very poor syntax and doesn't work but my question is how to handle errors from functions that have paramaters such that when there is no error thrown variables can be assigned?
Thanks!
TrimItOut
Post by TrimItOut »
However, this is a workaround to solve a problem that possibly has an easier solution rather than handling the error.
Ultimately I want to check whether the start state and goal state provided to OMPL are valid (collision free) before I use simOMPL.compute so that it doesn't throw the error mentioned in my first post.
To put this into context I do not want to compute the path (which is causig the error) if either the goal state or start state are invalid.
So I either need a way of checking the validity of both the goal state and start state or handling the error in some way.
You can have several arguments and return arguments too:
function generateAnError(arg1,arg2,arg3)
    a=a+1
    return arg1,arg2,arg3
    local arg1=42
    local arg2=57
    local arg3=21
    local result,retArg1OrErrorMsg,retArg2,retArg3=pcall(generateAnError,arg1,arg2,arg3)
    if not result then
        print("Error is: "..retArg1OrErrorMsg)
        print("No errors. Return values are",retArg1OrErrorMsg,retArg2,retArg3)
Now the best way to guarantee the validity of the start/goal states that you submit... is to check it yourself (you have all the infos needed to perform that check)
TrimItOut
Post by TrimItOut »
That's perfect, exactly what I was looking for!
