Page 1 of 2
remoteApi plugin problem
Posted: 14 Apr 2021, 21:46
by Al.mirante
Hi Coppelia Sim support team,
I have a problem with the latest version released of Coppelia Sim for macOS 10.15 (on macOS 11). When I launch a C++ application from Xcode using remoteApi, the simulation doesn't start automatically and even If I launch it manually the application doesn't start to comunicate with Coppelia Sim. The curious thing is that with the old version off CS 4.01 (rev1) there is no problem.
Thank you !
Re: remoteApi plugin problem
Posted: 16 Apr 2021, 09:41
are you using the legacy remote API? If yes, we shipped the wrong libraries. You can find the updated binaries in the remoteApiBindings github repository. MacOS libs will shortly be updated.
Posted: 16 Apr 2021, 10:51
by Al.mirante
Hello Coppelia Sim support team,
Thank you for the answer. Yes, I'm using legacy Remote API. Following your suggestion I substituted remoteApi.dylib in the package content of CoppeliaSim.app (in the exact path position of the wrong one), but it is the same: no incoming connections seems to be establisher with the continuous server running on port 19997.
Thank you.
Posted: 16 Apr 2021, 12:47
Please try again. We didn't yet update the MacOS files when you wrote back.
Posted: 18 Apr 2021, 11:02
by Al.mirante
Thank you again, but problem remains, I think it should be related to something else. AM
Posted: 20 Apr 2021, 08:41
Is there any error message or crash information?
Posted: 11 May 2021, 12:27
by Rufio2790
Dear all,
I've tried today the remoteApiBindings lib for MacOs (it seems they have been updated 5 days ago on github), but the problem persist with the version 4.2 (overriding the old one in the programming folder).
Version 4.1 works fine.
Posted: 11 May 2021, 14:18
In your CoppeliaSim bundle, in coppeliaSim.app/Contents/Resources, there is a file remoteApiConnections.txt. Can you copy that file to coppeliaSim.app/Contents/MacOS and see if that works? (make sure to restart CoppeliaSim).
If not, please try to start a remote API server service inside of a child script instead (simRemoteApi.start) and connect to that one.
Posted: 13 May 2021, 11:22
by Rufio2790
As you suggested, I moved the remoteApiConnection.txt from Resources to MacOs, and it worked!
It seems the trick solves the problem without overriding the remoteApi.dylib with the one that can be found on github.
Basically, at least on MacOS, copying the remoteApiConnection.txt to the MacOs folder works for version 4.2.0.
Thanks!
Posted: 14 May 2021, 08:53
Thanks for reporting back :)
