How to enable dynamic properties during simulation
Posted: 04 May 2021, 04:12
by Aadhithya K
Hello again
I would like to enable the dynamic properties of the model programmatically during a simulation.
The model is a CAD model and not a primary shape (if there would be any difference for it)
The model is initially static and after executing another function in the Lua script I would like to set the model to be dynamic.
Is there any way to do this with the Lua script?
I would like to set only the base of the model tree to be dynamic.
Thanks in advance
Re: How to enable dynamic properties during simulation
Posted: 04 May 2021, 14:27
yes, you can use some of following API functions for that. But make sure that simulation is not running when doing this, or reset the shape via sim.resetDynamicObject after such a change.
