How to start and stop the simulator externally
TrimItOut
Post by TrimItOut »
I am trying to run a set number of trials of a simulation that I have created. Once the robot reaches the goal it stops the simulation so I am trying to create a piece of code that then starts the simulation again until the required number of trials has been reached.
I have tried to use the following code in the lua command line within CoppeliaSIm however it simply doesn't run the simulation whilst it is checking the simulator state inside the while loop.
Code:
num_trials=10
for i=0,num_trials,1 do
  sim.startSimulation()
  print("trial number: "..i)
  while true do
    if sim.getSimulationState()==0 then
      break
print("ALL TRIALS finished")
Is there an easy solution to achieve this?
Thanks in advance!
Re: How to start and stop the simulator externally
did you have a look at this thread?
TrimItOut
Post by TrimItOut »
Exactly what I was looking for!
For anyone else looking for a similar solution I managed to implement the above functionality using an addon.
Documentation here: https://www.coppeliarobotics.com/helpFi ... addOns.htm
Thank you
