Dummy's problems of following an open path
anteto
Post by anteto »
HELLO!
I created an open path and added a dummy to make the dummy move along the path. I found that the dummy does not stop after moving from the start of the path to the end of the path. Instead, it returns to the starting point and repeats the previous movement. May I ask How can we make the dummy move along the open path and stop at the end? Here is the code for dummy to follow the path, the code comes from official documents.
    objectToFollowPath=sim.getObjectHandle(sim.handle_self)
    path=sim.getObjectHandle('Path')
    pathData=sim.unpackDoubleTable(sim.readCustomDataBlock(path,'PATH'))
    local m=Matrix(#pathData//7,7,pathData)
    pathPositions=m:slice(1,1,m:rows(),3):data()
    pathQuaternions=m:slice(1,4,m:rows(),7):data()
    pathLengths,totalLength=sim.getPathLengths(pathPositions,3)
    velocity=0.02 -- m/s
    posAlongPath=0
    previousSimulationTime=0
function sysCall_actuation()
        if errorMsg then
function coroutineMain()
    while true do
        local t=sim.getSimulationTime()
        posAlongPath=posAlongPath+velocity*(t-previousSimulationTime)
        posAlongPath=posAlongPath % totalLength
        local pos=sim.getPathInterpolatedConfig(pathPositions,pathLengths,posAlongPath)
        local quat=sim.getPathInterpolatedConfig(pathQuaternions,pathLengths,
                                                 posAlongPath,nil,{2,2,2,2})
        sim.setObjectPosition(objectToFollowPath,path,pos)
        sim.setObjectQuaternion(objectToFollowPath,path,quat)
        previousSimulationTime=t
        sim.switchThread()
CHEERS!
Re: Dummy's problems of following an open path
the position of the dummy along the path is held in variable posAlongPath. That variable is however made cyclic via the modulo operator:
So remove above line, and it won't operate in a cyclic manner anymore.
anteto
Post by anteto »
hello!
thanks!you guys are really helpful!
cheers!
