I set the full screen simulating which is totally cover by a floating view of a camera, and I set a dialog appearing when simulating, but the full screen will end when the dialog appear, and I need to click back to the full screen. how to solve this problem? I want to keep the full screen when the dialog is appearing. Please help me solve this problem, thank you!
question about full screen simulation
Re: question about full screen simulation
the full screen mode is tricky when interacting with the user via dialogs. The full screen mode usually doesn't end when a dialog shows, but the (empty) main window and the dialogs will partially cover the full screen mode. The only option is to move those items to the side, or better, onto another screen if available.
Thanks for your answer, it helps a lot! But when I use the old version's V-REP(V3.1.2), the full screen mode will not be covered by the main window, and the dialog can also display on the full screen view.coppelia wrote: ↑03 Jun 2021, 15:30 Hello,
not sure what has changed, but this is handled by the Qt framework.
