required python version of simExtROS is different from default in ROS melodic
lyh458
Post by lyh458 »
I tried to load ros interface plugin, so I git clone and build [simExtROS](https://github.com/CoppeliaRobotics/simExtROS), but have several problems and errors bother me. Here are my environments:
- system: ubuntu 18.04
- ROS: melodic
- CoppeliaSim: V4.2.0
**Question 1:** _can build with python 3, but run with python 2?_
see the dependencies list of [libPlugin](https://github.com/CoppeliaRobotics/libPlugin), **python 3.8 is required**, but the **default version of ROS melodic is python 2.7**, and I tried to build with the default, a python 3 error showed:
```log
CMake Error at /usr/share/cmake-3.20/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find Python3 (missing: Python3_EXECUTABLE Interpreter)
So **I created a python 3 env with conda, and builded successfully**. And run:
```bash
source ~/.bashrc
roscd sim_ros_interface
roscd ros_bubble_rob
``roscd`` the two packages successfully and all is well so far.
Is that right? If so, And why two versions of python are required?
**Question 2:** _plugin 'ROSInterface': load failed_
I copied ``libsimExtROSInterface.so`` to the root folder of CoppeliaSim, create two new terminator (default ros environment, python 2) and then run:
```bash
roscore
```bash
./coppeliaSim.sh
A ros interface error showed:
```log
[CoppeliaSim:loadinfo] plugin 'ROS': load succeeded.
[CoppeliaSim:loadinfo] plugin 'ROSInterface': loading...
[CoppeliaSim:error] plugin 'ROSInterface': load failed (could not load). The plugin probably couldn't load dependency libraries. For additional infos, modify the script 'libLoadErrorCheck.sh', run it and inspect the output.
So I tried to follow the prompt, modified and then run ``./libLoadErrorCheck.sh``, seem no dependency is missing, here is the log:
```log
linux-vdso.so.1 (0x00007f20d2758000)
libimage_transport.so => /opt/ros/melodic/lib/libimage_transport.so (0x00007f20d0eb3000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f20d0caf000)
libtf.so => /opt/ros/melodic/lib/libtf.so (0x00007f20d0a86000)
libroscpp.so => /opt/ros/melodic/lib/libroscpp.so (0x00007f20d06f1000)
librosconsole.so => /opt/ros/melodic/lib/librosconsole.so (0x00007f20d04bb000)
libroscpp_serialization.so => /opt/ros/melodic/lib/libroscpp_serialization.so (0x00007f20d02b8000)
librostime.so => /opt/ros/melodic/lib/librostime.so (0x00007f20d0098000)
libboost_system.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_system.so.1.65.1 (0x00007f20cfe93000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f20cfc74000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f20cf8eb000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f20cf6d3000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f20cf2e2000)
libmessage_filters.so => /opt/ros/melodic/lib/libmessage_filters.so (0x00007f20cf0dd000)
libclass_loader.so => /opt/ros/melodic/lib/libclass_loader.so (0x00007f20ceeb6000)
libroslib.so => /opt/ros/melodic/lib/libroslib.so (0x00007f20ceca3000)
libboost_filesystem.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_filesystem.so.1.65.1 (0x00007f20cea89000)
libtinyxml2.so.6 => /usr/lib/x86_64-linux-gnu/libtinyxml2.so.6 (0x00007f20ce875000)
libconsole_bridge.so.0.4 => /usr/lib/x86_64-linux-gnu/libconsole_bridge.so.0.4 (0x00007f20ce670000)
/lib64/ld-linux-x86-64.so.2 (0x00007f20d2530000)
libtf2_ros.so => /opt/ros/melodic/lib/libtf2_ros.so (0x00007f20ce3c1000)
libtf2.so => /opt/ros/melodic/lib/libtf2.so (0x00007f20ce18d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f20cddef000)
libxmlrpcpp.so => /opt/ros/melodic/lib/libxmlrpcpp.so (0x00007f20cdbd0000)
libcpp_common.so => /opt/ros/melodic/lib/libcpp_common.so (0x00007f20cd9c5000)
libboost_thread.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_thread.so.1.65.1 (0x00007f20cd7a0000)
libboost_chrono.so.1.65.1 => /usr/lib/x86_64-linux-gnu/libboost_chrono.so.1.65.1 (0x00007f20cd59b000)
librosconsole_log4cxx.so => /opt/ros/melodic/lib/librosconsole_log4cxx.so (0x00007f20cd380000)
librosconsole_backend_interface.so => /opt/ros/melodic/lib/librosconsole_backend_interface.so (0x00007f20cd17e000)
liblog4cxx.so.10 => /usr/lib/x86_64-linux-gnu/liblog4cxx.so.10 (0x00007f20ccdb5000)
libboost_regex.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_regex.so.1.65.1 (0x00007f20ccaad000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f20cc8a5000)
libPocoFoundation.so.50 => /usr/lib/libPocoFoundation.so.50 (0x00007f20cc4fc000)
librospack.so => /opt/ros/melodic/lib/librospack.so (0x00007f20cc2b9000)
libactionlib.so => /opt/ros/melodic/lib/libactionlib.so (0x00007f20cc098000)
libapr-1.so.0 => /usr/lib/x86_64-linux-gnu/libapr-1.so.0 (0x00007f20cbe63000)
libaprutil-1.so.0 => /usr/lib/x86_64-linux-gnu/libaprutil-1.so.0 (0x00007f20cbc38000)
libicui18n.so.60 => /usr/lib/x86_64-linux-gnu/libicui18n.so.60 (0x00007f20cb797000)
libicuuc.so.60 => /usr/lib/x86_64-linux-gnu/libicuuc.so.60 (0x00007f20cb3df000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f20cb16d000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f20caf50000)
libboost_program_options.so.1.65.1 => /home/lyh/Codes/robot_ws/CoppeliaSim_Edu_V4_2_0_Ubuntu18_04/libboost_program_options.so.1.65.1 (0x00007f20caccf000)
libpython2.7.so.1.0 => /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 (0x00007f20ca752000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f20ca54b000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f20ca313000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f20ca0e1000)
libicudata.so.60 => /usr/lib/x86_64-linux-gnu/libicudata.so.60 (0x00007f20c8538000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f20c8335000)
- **Question 3:** _can use libsimExtROSInterface.so of V4.0.0 in V4.2.0?_
Since the required python version of CopperliaSim V4.0.0 is python 2 and same as melodic, so I copied the ``libsimExtROSInterface.so`` builded by simExtROS branch ``coppeliasim-v4.0.0`` to the root folder of CoppeliaSim V4.2.0, and run ``./``, every plugins are load successfully except several warnings:
```log
[CoppeliaSim:loadinfo] plugin 'ROS': loading...
[CoppeliaSim:loadinfo] **plugin 'ROS': load succeeded.**
Plugin 'RosInterface': warning: replaced variable 'simROS'
Plugin 'RosInterface': warning: replaced function 'simROS.subscribe@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownSubscriber@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.subscriberTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.advertise@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownPublisher@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.publisherTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.publish@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceClient@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownServiceClient@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceClientTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.call@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.advertiseService@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.shutdownServiceServer@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.serviceServerTreatUInt8ArrayAsString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.sendTransform@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.sendTransforms@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportSubscribe@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportShutdownSubscriber@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportAdvertise@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportShutdownPublisher@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.imageTransportPublish@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getTime@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamInt@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamDouble@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.getParamBool@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamString@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamInt@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamDouble@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.setParamBool@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.hasParam@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.deleteParam@RosInterface'
Plugin 'RosInterface': warning: replaced function 'simROS.searchParam@RosInterface'
[CoppeliaSim:loadinfo] **plugin 'ROSInterface': load succeeded.**
Do these warning matter?
- **Tutorial correction required**
[The tutorial](https://www.coppeliarobotics.com/helpFi ... torial.htm) about how to have CoppeliaSim ROS enabled seems a little outdated
> Copy the devel/lib/libsimExtROS.so file to the CoppeliaSim installation folder. The plugin is now ready to be used!
It seems that no ``libsimExtROS.so`` is generated after building, but ``libsimExtROSInterface.so``, and ``libsimExtROS.so`` can be found in the root folder of CopperliaSim in default.
Thanks.
Re: required python version of simExtROS is different from default in ROS melodic
lyh458 wrote: 08 Jun 2021, 04:21 Hi,
- ROS: melodic
Python 3 is a build-time dependency of libPlugin, so you are required to have Python 3 at the time of compiling simExtROS.
However other ROS-related files are generated via ROS' Python modules, which for ROS melodic are only available for Python 2. So you are required to have Python 2 and ROS Python libs at the time of compiling simExtROS. (you better off upgrading your Ubuntu to 20+ and using ROS Noetic at least; Btw, if compiling for ROS Melodic, make sure to use the 'melodic' branch of simExtROS!)
However, you don't need any Python interpreter for loading the ROS plugin.
lyh458 wrote: 08 Jun 2021, 04:21 **Question 2:** _plugin 'ROSInterface': load failed_
This usually means that some library required by the plugin cannot be loaded.
lyh458 wrote: 08 Jun 2021, 04:21 - **Question 3:** _can use libsimExtROSInterface.so of V4.0.0 in V4.2.0?_
Generally speaking, no.
There are slight API changes between every release, so chances that you can load an older plugin in a newer CoppeliaSim release are very low.
lyh458 wrote: 08 Jun 2021, 04:21 Since the required python version of CopperliaSim V4.0.0 is python 2 and same as melodic
Again, once the plugin is compiled, no Python interpreter is required.
lyh458 wrote: 08 Jun 2021, 04:21 [CoppeliaSim:loadinfo] plugin 'ROS': loading...
Plugin was originally named 'ROSInterface', then it has been renamed to 'ROS'.
Remove simExtROSInterface.so.
lyh458
Post by lyh458 »
Thanks for your reply.
However, I followed the prompt, modified and then run
, seem no dependency is missing. The log is attached in question 2, could you help me check if any library or dependency is missing?
Thanks again!
The 'ROS' plugin loads fine, what's the problem with that?
lyh458
Post by lyh458 »
fferri wrote: 09 Jun 2021, 09:47 The 'ROS' plugin loads fine, what's the problem with that?
Sorry, my mistake, I used to think that libsimExtROS.so and libsimExtROSInterface.so are different, but actually they are same. I just removed libsimExtROSInterface.so as you mentioned in last reply, and everything look good!
Thanks!
