How to create an object with a customized name?
dada_17528
Post by dada_17528 »
When I use Lua script to create a new object, (e.g. a cuboid), I can not give the new object a proper name.
The function usage is
int objectHandle=sim.createPureShape(int primitiveType,int options,table[3] sizes,float mass,table[2] precision=nil)
It is not easy to use when the created object does not have a customized name.
So, how to create an object with a customized name?
Re: How to create an object with a customized name?
you will have to use sim.setObjectName (and maybe also sim.getObjectName), but keep in mind that object names have to be unique. Use sim.handleflag_silenterror to generate silent errors and find out whether a name already exists (or contains illegal chars).
Starting with CoppeliaSim V4.3.0, object names will be deprecated and object aliases used instead: they will allow for non-unique aliases, and be very convenient for object access via an absolute or relative path, e.g. sim.getObjectHandle("./path/to/alias").
